im about to click purchase right now, someone please answer![]()
I want to a) eliminate my headunit b) use my stock system c) add sirius to my setup carpc setup. how would you do this?
is it as simple as plugin into the line input and turning it on and off when i wanna hear it ?
Go on and do it, do it, Do it 'til you're satisfied,
Whatever it is, do it, Do it 'til you're satisfied.
CarPc progress |OOOOXCOOOO| 57%
Well, a) easy... rip out the headunit... hopefully it wasn't your amp. If it was then install amp.
b) ok... hook up PC to AMP.
c. Sirus is expensive and not a lot of software support for it![]()
Originally Posted by 0l33l
lets make some software![]()
I am still waiting for this to be available timetrax.
That will cost youOriginally Posted by ltrain1007
1) Take out the HU...as said, if you don't have an external amplifier, now you'll need one.
2) By stock system i'll assume your door speakers. If it's the BMW under your avatar, there's always a slight chance it's amplified, and that makes things way more complex (if it is). You might have to rip everything out and start from scratch.
3) Nothing like timetrax or serial control for Sirius yet. So...standalone Sirius through a line-in..
