Results 1 to 10 of 12
Thread: Ah snap! I done blew me a fuse!! And possibly my amp!!
    Raw Wave tbird2340's Avatar
    Oct 2003
    Poland, OH
    Ok.. So I'm jamming to Another Brick in the Wall redone by KoRn on the way home from lunch and while I'm belting out "WE DON'T NEED NO EDUCAT...."
    my system totally goes quite.. At first I think that my carputer just locked up but it wasn't. Then I start to smell something electrical so I switch over to the radio and I got no sound there. I pinpoint it to my AMP and start to worry that I freakin fried it. Luckily I'm about 200 yds away from home. I get home and feel the amp. Feels very warm but I think that is pretty usual..
    I take off the caps so I can see the power LED and turn on my truck. I get nothing on my AMP. So then I really thought I fried it.. Then I thought to check the fuse. It was blown..
    What would cause this and what should I check BEFORE I get another fuse?
    Man I hope my amp isn't blown. Don't really have the money to get a new one .
    Thanks for any help!
    Current Vehicle: 2007 Dodge Nitro
    Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
    First Vehicle: 2003 Ford Ranger
    May 2005
    low voltage will causes the current to go up
    small awg wire will also cause a voltage drop
    you did not say size of power watts/rms and size of cap or how long the wire run/size of wire
    make sure your ground at the battery and the ground for your amp are clear of rust/corrosion becase it can cause resistance also
    Oct 2003
    Poland, OH
    Not sure what gauge my wire is. I bought an amp wiring kit at my local shop and told them what I was using so I'm sure it's appropriate. The amp is a Rockford Fosgate 500X. The run is from the battery to the amp which is right behind my truck seat. The ground wire goes from the middle of my truck (under the console) to the amp.
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    hrm, last time I had that burning smell, the power transistors in the amp blew and took the fuse with them. But a trip to my local electronics store to get the NTE replacements fixed that problem.
    I have had 2 amps do it to me for no reason whatsoever, but after putting in the replacements they worked great for a long time after
    how old is the amp?
    肚子笑痛了
    S60 Install
    Oct 2003
    Poland, OH
    Not sure.. Bought it used. It doesn't look that hold cosmetically. How would I tell if that is what's wrong with mine?
    May 2003
    Miami, FL
    Just take off the back, you will see a circuit board with rows of transistors on either side, just check them all, the culprit will probably have a nice crack in it with burn marks if that was your problem, but if you were smelling burning and it was coming from the amp that is probably the problem. The only other thing i've had happen on a fosgate was some sort of protection diode that exploded and needed replacement
    but it's worth a look before you replace the fuse
    肚子笑痛了
    S60 Install
    May 2005
    well try a new fuse if the amp is blow/damaged that rockford will let you know right away by blowing the new fuse
    rockfords seem to take a beating and keep on ticking
    also see if your impedance on you speaker wiring are meeting the amps specs
    real low impedance will also cause high current draws
    just a thought but i doubled my factory ground under the hood for extra saftey for high currents
    Oct 2003
    Poland, OH
    On a side note. It has been running fine for almost a year.
    May 2003
    Miami, FL
    mine was the same way, worked great for a year or two, was just cruising one day and it went
    肚子笑痛了
    S60 Install
    Oct 2003
    Poland, OH
    I put another fuse in and it blew instantly. I opened up the amp and took some pics:
    As you can see closely in the second picture there is a fried wire on that thing.
    Any chance you can tell from the pics if it can be fixed?
  1. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
