Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Decibal Output Question
    May 2005
    If for example, a single 10" subwoofer with 350rms watts running through it put out 45dB... what woould the dB output be when another 10" sub is added with 350rms watts running through it also? Is it generally 2x the output in decibals or a little less...?
    May 2005
    oops not 45 db.. that was just a random value... A more accurate dB for the 10" is 110.
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    If you could double your db's but just adding another 10" sub in there, you'd be the current db world record holder. The answer to your question is the increase would be a lot less than double.
    ATVMS.com
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    its 3db more, double the input and you get a 3db increase
    Signature: [==||========] 20% complete
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by Nic
    some one listened in physics
    if i remeber,, u will double the pressure level
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    i have a phyics exam soon :S i wish it was on that stuff tho, its on quantum physics which is hell hard compared to f=ma
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Good luck with your exam
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    thanks, i'm gonna need it :P
    _
    Mar 2004
    Little Elm, Texas
    the general rule of thumb is that if you double your cone area you will double your pressure - meaning you will gain 3 db. Also, if you double your power you will double your pressure, meaning an additional 3 db.
    but there is a point of diminishing returns here.
    if you look at the SPL vehicles of a few years ago they all used a massive amount of subs and even more power. The gobs have power has stayed the same, but they are now realizing that you can get higher numbers with less subs and a better built box....not to mention a smaller vehicle (less air space to build pressure in)
    contrary to what a lot of people think, competing in SPL can be a heck of a lot of fun!
    Jan Bennett
    Jun 2004
    Bay Area, California
    yes. double cone area, double power, add 3 db. so a second 10 with a second 350 rms would yield a total of 6 dB on the meter..... max
    I struggled with this for a long, long time. what it comes down to is that the meter is not a measure of air "pressure" but rather accoustic "energy". Or is it the other way around? Honestly, it doesnt matter.
    the point of the matter is that the meter will read 6 dB (max) higher when you double your displacement. which is exactly what you are doing by adding both a subwoofer AND doubling power.
    now, the funny thing to keep in mind is that because of this, while the relationship between excursion and power requirements is still linear, its not a 1 to 1 relationship! Thus, to double the excursion (remember double excursion is double the air motion and therefore a 6 dB gain on the meter!) keeping only one subwoofer would require FOUR times the power! Thus we see that the rule of double power for a 3 dB (max!) gain holds true! assuming the cone of the woofer can actually travel that far!
    last thing to think about is, why make the distinction between energy and pressure? well, doubling the excursion IS just a 3 dB gain! in pressure (or is it energy? Honestly, it doesnt matter). Thus, we need double the power AND double the cone area to get our 3 dB gain! but the meter will read 6 dB (max!) up.
    get it?
  1. Newbie question
    By jaydm in forum General Hardware Discussion
    Last Post: 10-21-2006, 10:07 AM
  2. Complete Newbie Question.
    By DomesticImport in forum Newbie
    Last Post: 07-07-2005, 06:24 PM
  3. Power Supplies Specs Question
    By rushnrockt in forum Power Supplies
    Last Post: 02-19-2005, 01:34 AM
  4. Dual output blues
    By septicdeath in forum LCD/Display
    Last Post: 02-11-2005, 02:56 PM
  5. amplifier remote output question
    By Magsino in forum Car Audio
    Last Post: 01-05-2005, 12:10 PM
