Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Sound systems.
    Apr 2005
    Sound systems.
    Hello everyone,
    I need opinions or a person who knows audio very very good. Alright I am looking to hook up my car with a good car stereo system. I have the stock Infinity system in there now. The 2 different types are:
    Infinity Kappa Perfects 6.1 Component system 6.5"
    Not sure if they make 6X9 Kappa Perfects. =/
    Infinity Kappa Perfect Subwoofer (Not sure on size any opionons? I listen to Rap and Rock pretty equal on listening to both) Also they come in Dual or single voice coil. What's better?
    OR
    Alpine Type R 6.5"
    Alpine Type R 6X9
    Alpine Type (R or X) Subwoofer
    Thanks for your input.
    New York
    i am a fan of infinity although there is nothing wrong with mixing and matching. There is no difference performancewise between dual or single however it reallt depends on your amp. If your amp does 600 at 2ohms and 400 4ohms then you want the dual 4ohm so that you get the most power. If you want to maximize the usage of your amp and sub which may not always be the best idea. Do some more research and find a couple of amps you are interested in and then decide. Some amps arent 1ohm stable and if you are going to run two subs that might be a problem for dual 4ohm.
    FLAC -zip-'s Avatar
    Ontario/Canada
    Go to a car stereo place and have a listen. Bring some CD's of the type of music you like.
    Sound Stage
    Eclipse|MTX|Infinity
    Apr 2005
    Quote Originally Posted by ill_ace
    not really. DVC makes the sub twice the power SVC does.
    MX5 SQ Roadster
    Deck: Clarion DRX9575Rz
    Front Stage: Boston Pro 6.5
    Sub: IDQ10D2V.2
    Amp: PG Xenon X100.4
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    Quote Originally Posted by chan
    thats a joke right?
    Signature: [==||========] 20% complete
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    Some good advice here...Zip is on the money.
    The difference between DVC and SVC is install options. A DVC woofer gives you more options on impedance configurations. With these options it is often easier to achive max performance from your amp. A DVC sub with two 4 ohm coils can either be a 2 ohm driver or a 8 ohm driver. Then couple that with another DVC driver and it could be 4 ohm, 1 ohm, or 8 ohm. A 4 ohm SVC sub will only give you 4 ohm and a pair will give you either 2 ohm or 8 ohm. So you see there are alot more options with DVC subs. On another note I have never heard a difference between a SVC and a DVC of the same brand.
    Apr 2005
    No one around my area sells the infinity so I can really listen to them. I have heard Alpine.
    Maximum Bitrate djXternal's Avatar
    Jul 2004
    Tampa, FL
    I personally like JL's the best, although they can be a bit pricey
    Debating on installing a carpc in my Jeep.....
    New York
    jls are good but they are way too overhyped. There is other stuff out there that is better and around the same price. Jl is a brand that will impress anyone just because of the name so if you dont care about that go with other brands.
    Jul 2004
    Tampa, FL
    others brands such as??.... ive heard alot of subs and havent liked any of as much as my jls
    but subs are a great deal of personal preference
  1. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  2. Sound cards from incarpcs , sacrificing sound quality?
    By skinhead in forum General Hardware Discussion
    Last Post: 09-02-2004, 03:05 AM
  3. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
  4. Question - Those with sound systems (subs) and computers....
    By animus in forum General Hardware Discussion
    Last Post: 05-19-2003, 10:07 PM
  5. Why do sum Sound systems hav huge caps ?
    By X-treme in forum General Hardware Discussion
    Last Post: 09-27-2001, 09:16 AM
