Results 1 to 7 of 7
Thread: Some strange noise...
    Sep 2003
    Saskatchewan
    Hi all, I hope someone can help me with this...
    As you might know, I'm using my Compaq Ipaq 3850 to play my mp3's with a 512 mb sd card. Up till recently I was using a fm modulator, but today I hooked up my old 2 channel 150 watt amp and ditched the modulator...
    Here's the thing... When I'm running my ipaq with the car adapter plugged into the lighter I get some odd noise (kinda a swishy sound and some static like sound) If I turn it up enough I cant hear the noise below the music... but as soon as I remove the cig adapter and the ipaq runs on it's internal battery it sounds great, no more noise...
    I'm using good wires and have a good ground at my amp. the noise only happens when I powering the ipaq with the car adapter.
    Thanks for any help
    TiTUS
    Maximum Bitrate shizzle's Avatar
    Mar 2005
    Sarasota, FL
    Its probably in need of a ground loop isolator (radio shack).
    Before you run out and buy one, though, make sure your audio cables arent near the power cable when it is plugged in, as noise would definitely result from that as well.
    Carputer status: [-*---------]
    Im thinking laptop...
    Sep 2003
    Saskatchewan
    Thanks shizzle... I went outside and re-routed my audio cables away from the power cables and it made no difference, looks like I need a ground loop isolator... Judging by the googled image of one it just goes inline with my rca audio cables right? What does a ground loop isolator do exactly?
    TiTUS
    Mar 2005
    Sarasota, FL
    Basically you are hearing interference from the power in some form or another. Since I am no expert and only understand the basic premise, I will offer you a little something I found with
    http://www.bcae1.com/glisoltr.htm
    Sep 2003
    Saskatchewan
    I decided to try something... I took my powerpack outside (good for boosting cars and powering stuff while camping) and plugged my cig adapter for my ipaq into it and there was no noise at all in the system, then I plugged the cig adapter back into the car's cig lighter and instant noise...
    TiTUS
    Sep 2003
    Saskatchewan
    Quote Originally Posted by shizzle
    lol, I had just found that site myself using google just before you posted it for me... I had just started reading it when I had the idea to try my power pack outside...
    TiTUS
    Mar 2005
    Sarasota, FL
    Quote Originally Posted by TiTUS
    TiTUS
    Yeah, the isolator will probably help, but I would recommend a different source for power, because that cig adapter is obviously not clean power. I would be worried if it were humming that much for me.
  1. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 12:41 PM
  2. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 10:31 AM
  3. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 02:41 AM
  4. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 01:33 PM
  5. Replies: 9
    Last Post: 06-22-2004, 01:24 PM
