Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: psu to power amp and speakers?
  1. #11
    qaz
    qaz is offline
    Oct 2004
    Quote Originally Posted by Nic
    computer power supplies arent designed to deal with a current load that fluctuates as much as an amp will, in short, its a bad bad idea
    but a cap should smooth it out fine. either way, whats the worst that could happen, itll kill the psu. its only $25 anyway, i figure its worth a shot. i wanna recess the speakers in the ceiling in all the rooms and for the price of 6.5" car speakers it seems like i cant lose. so i guess it comes down to...is 20-25 amps enough to power this?
  2. #12
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    i've used car speakers on my home stereo before without any issues and i had a relatively crappy reviever
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
  3. #13
    FLAC evandude's Avatar
    Mar 2005
    Maine
    I agree, just get a reciever. car amps are designed to run on 12 volts, recievers are designed to run on AC. It would be stupid to convert AC to 12 volts just to run an amp, when you can run straight off AC... not to mention, a reciever is much more suited to home use anyway (can switch between different audio sources, can have EQ, you can use a remote control, built-in radio, etc etc)
    using a car amp indoors seems about as smart as using a reciever in the car on an inverter.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
  4. #14
    qaz
    qaz is offline
    Oct 2004
    so i can use a home reciever with car speakers and it would sound and act the same?
  5. #15
    qaz
    qaz is offline
    Oct 2004
    i was just looking at some on ebay and theyre all 8 ohms as opposed to 4 or 2 like car speakers. is this the only difference? whats the drawbacks? thanks
  6. #16
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    its difficult to get lots of power out of a car system to power audio becuase its at a low voltage, in orger to get a decent amount of power the voltage must be stepped up. For example an 8ohm speaker that peaks at 200w needs 40v to operate, in order to compensate for this speakers in cars are generally rated at 4ohms or lower, a 4 ohm speaker at 200w only needs 20v. Its harder to produce an accurate speaker with a lower impedence which often makes car speakers more expensive (or worse sounding) than home audio speakers, amplifiers are also often more expensive because they have to step the voltage up.
    Another important factor to note is that the enclosure of a speaker plays a big part into how well it peforms, putting speakers into walls when you could easliy make a nice box for them is never a good idea unless you dont care about bass at all, home speakers mostly come in boxes wich are specialy designed with the speaker in mind, but theres nothing stopping you buying the driver and making a box yourself.
    Can you run car stuff of a home amp? yes, so long as the amp is stable down to 4 ohms
    Signature: [==||========] 20% complete
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  3. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  4. matching amp with speakers.
    By ketchup318 in forum Car Audio
    Last Post: 01-19-2005, 02:01 PM
  5. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
