Results 1 to 10 of 16
Thread: psu to power amp and speakers?
    qaz
    qaz is offline
    Oct 2004
    i was wondering for my home, if a computer power supply has enough power from the 12v line to power and amp with 4 speakers. thanks
    Sean
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    yeah it sh ould be ok, but deppends on the psu and amp, but in short, yes it can be done.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    No way man. It won't be powerful enough. If your talking about a 4 channel car amp? Running that 14 guage wire to power it will not have enough power
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I hear that AT PSUs have very strong 12v lines. But don't quote me on that.
    FLAC evandude's Avatar
    Mar 2005
    Maine
    you'll probably find AT supplies with 12v lines around 8 amps max... which isn't even 100 watts. maybe if you go buy one of those HAM radio power supplies, the bench ones that give you a cigarette lighter output.... those are sometimes rated at 20 or more amps output. However, you'll probably want to use a big cap on it, because the intermittent current draw will probably be much greater than the constant current draw...
    or you could easily do it if you just get a car battery and a nice heavy duty car battery charger... run it with the charger on and connected and you should be fine.
    but the real question is... WHY?
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Yes it works, dont put the gain too high on the amp. (I did it to test my subs and radio when I got them to see if they worked).
    qaz
    qaz is offline
    Oct 2004
    click any of the links on the psu tiger direct page. they say how many amps each one has on the 12v line.
    http://www.tigerdirect.com/applicati....asp?CatId=106
    is 25 amps enough then?
    evandude: i wanna have one central computer in my house to control maybe 12 speakers throughout. ebay has 6.5" speakers for $20 a pair. i figure this is one of the easiest and cheapest ways of doing it. however, im always open for suggestions.
    Thanks guys
    Fusion Brain Creator
    Mar 2005
    you can get 5 channel home theater amps for $50 each used
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by greenman100
    where at?
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    computer power supplies arent designed to deal with a current load that fluctuates as much as an amp will, in short, its a bad bad idea
    Signature: [==||========] 20% complete
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  3. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
  4. matching amp with speakers.
    By ketchup318 in forum Car Audio
    Last Post: 01-19-2005, 02:01 PM
  5. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
