Results 1 to 3 of 3
Thread: Blazer door speaker installation help
    Newbie ErikArmbrust's Avatar
    Apr 2005
    Nebraska
    I have a 2000 blazer, and I just bought new speakers for the doors and dash.. but I have no idea how to get the door panels off. Do I need some huge tool to pry it off or something?
    AHH! I can't find anything on google either. This is getting very frustrating. I would much appreciate any help!
    Thank you
    Finished carputer:
    2000 Black Blazer
    Construction/ finished/ before
    Constant Bitrate Lando's Avatar
    Apr 2002
    The place to go
    The best place to go is www.carstereohelp.com ,but I'll tell you now it cost. I think it's like 3.99 for instructions on head unit and speaker removal. They have everything so I'm sure they have what you need.
    Aut cum scuto, aut in scuto
    Apr 2005
    Nebraska
    Well, instead of paying for **** on the internet... I decided to figure it out myself.
    First off in the front doors there are 2 hex screws in-layed under the door handle part, and one screw behind the door latch on cover plate. Just pop the cover plate off after the screw is removed, and the other 2 hex screws. Then take a long flat blade screw driver and pry between the plastic door panel and the metal car door until the clips all pop out all around. Then remove the control assembly piece in the door by pulling up the front side first (closest to dash) and then back side, then tilt it and put it through the hole it was mounted in. Then push up on the door to get the lip off the top out of it's seat, and remove the panel piece completely.
    Back doors are same process, except the door handle mounting screw are under a little piece of plastic about 1/2"X 3" in the handle depression which you can pop off with a falt blade screw driver. Then take off the door latch cover plate and screw like before. Then remove the frame pieces around the window by simply prying off the one farthest from the hinge, and unscrewing the one closest to the hinge. And lift upward and then out on the door. The window up/down switch also will have to be removed. Just put a flat blade screw driver under and edge of it and pry upward. Then remove the black connector that fit onto the bottom of that switch. Then remove the door panel.
    I'm glad I didn't pay some guy $120 to do this for me. Simple stuff once you figure it out.
    If I wasn't very clear on something let me know and I'll try to clarify.
    Hope it helped those in my previous predicament.
    Finished carputer:
    2000 Black Blazer
  1. Proper Installation of GPS Receiver
    By ummagawd in forum GPS
    Last Post: 04-22-2005, 11:07 AM
  2. Replies: 9
    Last Post: 03-31-2005, 02:40 AM
  3. Panasonic Head Unit Installation
    By Vicious in forum Car Audio
    Last Post: 01-16-2005, 01:35 PM
  4. Honda Integra DC5 (RSX) Installation
    By Robyn in forum Show off your project
    Last Post: 05-08-2004, 09:16 PM
  5. Car Stereo Installation Video's for Sale
    By johnram in forum Classified Archive
    Last Post: 09-05-2002, 10:27 PM
