Results 1 to 10 of 14
Thread: amp temperature
    May 2005
    amp temperature
    i was wondering what the average temperature was for most people on there amp is. the temperture in my car was about 70 degree Farneheit. I had my amp on for about 20 min and the the temp on the amp was 130F and the internal fan on the amp didnt turn on... i have an alpine mrv-f345. I am afraid that the fan might not be working and i just bought the amp so i can still replace it. should i been concerned?? i know that the amp will turn off automatically if the temperature gets to hot but i was just wondering before that might happen.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Unless you're having problems I wouldn't worry too much about it. How do you know what the temp was on the amp? Was it on the heatsink, or is there an internal temp meter? If it's brand new, I wouldn't be too concerned. Otherwise, try calling Alpine and ask them what the temperature tolerances are.
    May 2005
    Quote Originally Posted by Jahntassa
    ...Was it on the heatsink, or is there an internal temp meter? ....
    There is an internal temp meter on the amp
    Jun 2005
    I've had some amps that i think i could have cooked a steak on.
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    mmmm.. steak
    you could ahve different tracks with different current draw at a set volume for different cooking tempertures..
    "anyone seen my medium high CD?"
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    May 2005
    today it was 90 degrees outside and the amp got the 170 F, the fan on the amp still did not turn on
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    It is New Change it and compere the temp. with the one that you return.
    Constant Bitrate mbuchman's Avatar
    Feb 2005
    I would think you have a problem. I know for my amps, they have no fans or anything, just one giant heatsink, and none of them got hot even though I was giving them all I could handle (my goal was to overheat them, I failed.) But then again, each one of thsoe amps weighs 20 pounds, so like I said, huge heatsink...
    170 just seems really hot for an amp, so I would contact Alpine or something. Or, just run it at high power for a long time to try to overheat it.
    Matt
    May 2005
    Conyers, GA
    Depends on where the temperature sensor is. If it's on the amplifiers itself, then, yeah, it could probably easily get that high...
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    have you tried searching to see at what temp the fan is supposed to turn on?
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. Replies: 6
    Last Post: 03-20-2007, 11:16 PM
  3. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  5. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
