Results 1 to 9 of 9
Thread: Amp Question
    Jun 2005
    Amp Question
    I am not new to computers, but I am very new to car audio. I wish to replace my factory head unit with a carputer and LCD. What kind of amp can I buy or make that can output the sound to my 4 factory 4Runner speakers and be placed behind the screen?
    Tainted Love Cris's Avatar
    Romania
    You need a 4 channel amplifier. This is usually mounted in the trunk, or behind the seats, but I can't say I've ever heard of putting it behind the dash...They connect directly to the car's battery, and they do need some kind of air circulation around them...give up the behind the dash ideea, as usually the 4 channel amps are too big to fit in there anyway...
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    why not just keep the headunit and recess it behind the lcd?
    Romania
    Quote Originally Posted by binary.h4x
    What good will that do? not that it would be enough space to do that...
    Jun 2003
    Fairfax, VA
    the headunit has a built in amp and its already compatible with your speakers.
    Romania
    What I meant was, 1. there's probably not ebough space in there, and you probably need to trim the HU a little, and 2. if the HU doesn't have a remote or at least steering wheel controls, it will be of no use. Not to mention, in terms of sound quality an amp always reproduces a better sound then an HU, let alone a factory head unit.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Alpine made a small footprint 4 channel amp that would fit behind the dash LONG ago.. I had one at one point. Alpine 3531.
    Romania
    I can't find almost anything about it...
    Jun 2005
    chicago, Illinois
    That wouldnt do any good because you couldnt be able to control the headunit. And increasing the volume from just the aux of a headunit would not sound good at all.
    Second of all if you wanted to do a true 5.1 setup only few aftermarket headunits have 5.1 inputs which cost a few hundred. Might as well stick to the 4ch amp idea.
    And while you're at it i'd reccomend upgrading your speakers, becuase most stock speakers only accomadate 15 watts max and you'd surely burn them out with a even a moderately sized amp.
    PROGRESS:
  1. Hooking up amp question REM line
    By Jake in forum General Hardware Discussion
    Last Post: 02-09-2007, 02:19 PM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 07:03 PM
  3. PAC Audio Aux input amp pop question
    By knubile in forum Car Audio
    Last Post: 05-03-2005, 07:28 AM
  4. Amplifier/sub question...
    By technopsych in forum Car Audio
    Last Post: 05-22-2004, 05:28 PM
  5. seperate amp, no head unit question
    By saletel in forum General Hardware Discussion
    Last Post: 12-16-2001, 02:18 PM
