Results 1 to 4 of 4
Thread: Bass from PC
    Jun 2005
    Kent, England
    Bass from PC
    i have my main PC going through my A/V receiver at home through the 6 channel input and when using media player i never seem to get anything from the sub.
    however when i write mp3s to cd and play them in the car it sounds fine with the car sub
    question is if i'm using a 6-channel sound card how can i get the same bass when i install my car PC?
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    If you're using the Left Front and Right Front inputs on the receiver, then maybe it just passes them through to the left and right front outputs. You'd be better off using a "stereo" input (like AUX or CD or TAPE IN), or a digital (optical or coax input) since the receiver should decode that to Dolby Surround and feed the sub. You should also check if the L & R speakers are configured as "Large" or "Small" in the receiver. If they were set to "Large", the receiver will probably only direct the LFE (0.1) input to the sub.
    Jun 2005
    Kent, England
    so when i install my car PC what signal should i feed the sub amp?
    should it just get the same signal but use its own filter?
    or is there a better way to set it up?
    Constant Bitrate DJKhan85's Avatar
    May 2004
    Boston, Mass
    if you set up your soundcard to run in 5.1 channel mode, then you connect the sub(LFE) channel to the sub input. The trick can be to figure out if your sub output is tied to your center speaker output. if this is the case then you have to figure out which wire will lead to the sub and which leads to the center speaker. once the connections are made, and you are sure that it is all hooked up correctly, then the only problem will be on te software side of things. I could give more specific detail if I knew what soundcard you are using.
    Computer:
    COMPLETE SYSTEM OVERHAUL!!!!!!
    STAY TUNED IN THE UPCOMING WEEKS!
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
  3. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
  4. home pc problem
    By Mitokondria in forum Off Topic
    Last Post: 08-05-2003, 12:36 PM
