Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: Amp Volume Fluctuations
    Jun 2004
    I have my Carputer running directly through an amp powering the speakers (no head unit) and when I drive, the volume decreases when I step on the gas or brake pedals.
    I tried disconnecting the computer and using a standalone MP3 player as a sound source for the amp and it still did the same thing, so it shouldn't have anything to do with the computer. I also regroudned it, but it didn't help.
    The amp is 60 W x 4 and the alternator is 90 amps. The carputer has a 90W AC power supply fed by a 150 W RMS inverter.
    I'm out of ideas and I'd be very appreciative of some suggestions!
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    when you are driving you are probably around 14.4v when you are idling it'll drop between 12-13v so thats why the volume is going down. how new is your battery?
    one option is to get a louder exhaust, that way it'll sound louder at idle
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2004
    my battery is a couple of years old. I hooked a voltmeter up to the power leads to the amp and the voltage does fluctuate when idling if I turn on the headlights or AC, could that be the cause? If so, how can I fix that... other than muffling it out with a loud exhaust?
    Feb 2005
    Madison, WI USA
    Quote Originally Posted by Gewehrschuss
    I believe the traditional fix for this is to add a stiffening capacitor for the amp.
    Ive never used one myself though.
    Dec 2004
    Los Angeles Ca
    A cap wont solve that, they don't have the staying power, they are only used for quick bursts like a bass hit. I'm not sure exactly how to solve it, maybe an optima yellow top? what gauge wire are you using? do your headlights dim when the bass hits?
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2004
    I'm using 10-gauge wire
    Jun 2004
    no, my headlights don't dim at all
    Dec 2004
    Los Angeles Ca
    the wire may be too thin, it may be adding too much resistance into the system. maybe you could try a quick test by running some 4 gauge instead. a quick test may be to just get some 8 gauge wire and wire it in parrallel (doesn't have to be hidden, just run it on the outside for this test) to the 10 gauge that you have. keep your revs high and listen to the radio then let it idle and see if the volume goes down.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2004
    I'll give it a try, thanks for the suggestion
    Dec 2004
    Los Angeles Ca
    keep us posted if it doesnt work, we'll get down to the bottom of this. there are a few pro installers on this forum that may chime in with some other advice
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. volume control
    By JaxPt in forum Car Audio
    Last Post: 03-04-2008, 09:07 AM
  2. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  4. DVD volume much quieter than mp3 volume
    By bosskong in forum Centrafuse
    Last Post: 02-26-2005, 11:53 PM
  5. Replies: 11
    Last Post: 02-11-2004, 11:59 AM
