Results 1 to 5 of 5
Thread: HELP, Input Signal to AMP
    Constant Bitrate Power_nisse's Avatar
    May 2004
    Sweden
    Question HELP, Input Signal to AMP
    Hi There!
    Ive been reading in this forum Very much.. Can never be to much hehe
    Im gonna purchase a Carputer system within a month or two, after about 1 year of reading and saving money(student)
    Im thinking of getting an amp now.
    my question is about the input signal and what do you guys think about this amp look pretty good
    !Branson!
    0,05 % THD
    LED POWER ON Indicator
    Built-In Automatic Short Protection Circuit
    Built-In Automatic Over-Load Preotection Circuit
    Built-In Automatic Thermal Protection Circuit
    Bridgable to 4-3-2 channels
    Mosfet stage
    2 ohm stable
    Treble/Bass Control
    Bridgable output stage
    Adjustable In-Level
    Output Impedance: 2 ohm, 4 Ohm or 8 Ohm
    Input Impedance: 10K Ohm at LOW LEVEL INPUT
    Input Sensitivity: Einstellbar von 100mV bis 1 V
    Frequenz. Response: 10 Hz - 30 KHz +/-1 dB
    Max watt : 4x 1200W / 4 Ohm
    RMS watt : 4 x 120W / 4 Ohm
    RMS watt : 4 x 240 W / 2 Ohm
    Max watt Bridged: 2 x 2400W / 4 Ohm
    RMS Bridged: 2 x 240 W / 4 Ohm
    RMS Bridged: 2 x 480 W / 2 Ohm
    S/N Ratio: 80 dB
    Stereo Seperation: 50 dB
    Connections and cables i can manage etc, but what about the-->
    Output from sound card --> Amp input
    1.Is the soundcard comatible with that output signal ?
    Intregated sound car 1st then im gonna buy a Audigy card?
    2. S/N Ratio: 80 dB, Have been googling a little and found out that it might be a loss of sound quality?
    3. The Amp looks good but does it sound as good?
    What do you think? Any recommendation/comment is welcome =)
    Newbie DTACK's Avatar
    May 2005
    Belgium
    Overhere I never have heard yet of that amp...
    But I already don't like them stats:
    With a good amp the Max power is less or around double the RMS value, with your amp it is 10x as much...
    Probably just a brand trying to sell by it's "stats", it's not the only one, many manufacturers use the term "PMPO" (Peak Music Power Output) as a means for advertising!
    Usually, the PMPO power is about five to ten times higher than the RMS Power, and tells you actually nothing...
    May 2004
    Sweden
    Hmm ok, but i only look at the RMS wattage =)
    Or is the Amp just crap maybe?
    its a very low price aqtually 1600 SEK about 228 dollar and its quite nice looking too hehe
    May 2005
    Belgium
    Well I can't say the amp is crap cuz i don't know that amp or brand...
    But the "specs" and the prints on that amp do let suspect that they are trying to sell it not because of it's performance but cuz of it's "numbers"...
    Which makes me always very carefull
    May 2004
    Sweden
    oki, well i had an Pyle Amp in my last BMW 535 Really powerfulstuff!
    Gonna go for that one then or an Alpine/Rock ford =)
    Thanks för the help =)
  1. amp pop
    By dan__wright in forum Car Audio
    Last Post: 06-16-2005, 05:24 AM
  2. Computer input on amp?
    By ClubFed11 in forum Car Audio
    Last Post: 01-05-2005, 03:02 AM
  3. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
  4. Audio controller, more than one input source.
    By stimps in forum General Hardware Discussion
    Last Post: 10-10-2004, 08:12 PM
  5. directly wiring sound into stereo... anyone REALLY good?
    By ares in forum General Hardware Discussion
    Last Post: 12-30-2003, 05:37 PM
