Results 1 to 9 of 9
Thread: Extension cable for Honda HU connectors?
    Raw Wave justintime's Avatar
    Apr 2005
    Red face Extension cable for Honda HU connectors?
    I am trying to relocate my Head unit to a lower position on my dash. (Honda CR-V). The problem is that the stock cable is not long enough!!!
    Is there some sort of extension I can buy, to add another feet or two? I am envisioning a cable going from male to female, with the exact same pinouts that the OEM Honda HU connector has.
    If this does not exist, what are my options?! how are you all relocating your headunits to a lower spot in your dashes ?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    Jun 2005
    you could always do it the old fashioned way, splice the cable to make more length.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    They probably have it but I am not sure. There is a connector that plug in to the car harness for after market radio. This one is easy as every place has them. There is also a connector for using stock radio in different car. This one is a PITA to find. I know they have one for Toyota (86-90 cars). When you find the 2, connect 'em together to make an extension.
    Your other option is go to junkyard and get/cut/chop the "To-HU" end from the same car or different Honda (if it the same as yours). Now buy the "to-Harness" end and connect them together.
    Another option is cut your car harness and make the wire longer, but I am sure you dont' want to do that.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Apr 2005
    Thanks guys. Im trying to avoid cuttin the OEM harness. I think best option is to try to find the 2 connectors, and build an extension. (good luck with that LOL)
    2002 Honda CR-V
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    why you don't tap the cables???? so you don't need to cut.
    Apr 2005
    thanatos: can you elaborate? when you say tap, what exactly do you have in mind?
    2002 Honda CR-V
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    go to a car audio shop and get an aftermarket harness (that will give you the one half of the extension for between 12-20 dollars) then go th honda and get a connector for you stock radio (most likely around $40) then just add all the wire you need to make it long enough no cutting
    Aron
    Edit: sorry Matrix didnt see your post good idea though
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    hey my friend just extended it use networkign cable he ran his under his seat! lol
    Apr 2005
    OK guys, as it turns out, they sell both ends (both connector types) in eBay. I bought two, and will build an extension cable
    Total cost under $20.
    2002 Honda CR-V
  1. Replies: 8
    Last Post: 04-30-2003, 11:49 PM
  2. LCD extension cable ThinkPad 560
    By hakan in forum LCD/Display
    Last Post: 03-22-2002, 08:36 AM
  3. Can't get VGA extension cable to work...
    By SuperMatty in forum LCD/Display
    Last Post: 01-14-2002, 05:07 PM
  4. printer extension cable
    By blacktooth in forum General Hardware Discussion
    Last Post: 03-10-2001, 03:57 PM
  5. lcd cable length extension?
    By newbie in forum General Hardware Discussion
    Last Post: 03-13-2000, 06:31 PM
