It'll be tough to push much a sub with only 100W RMS... I'd seriously consider another, higher-power amplifier if you want to drive a sub (aim for at least 300w RMS, which most monoblock subs are)...
My system is complete now minus one critical component - a sub
I need something nice and efficient, as I dont have alot of power to play with.
Amp: 4x50W RMS - rear channels bridged for sub.
Car: subaru liberty (legacy) wagon
I want a single 12" sub.
I have always liked the JL's but im tired of waiting for the new W1 series to be released. does anyone have any good alternatives to this sub?
that amp will probably bridge to ~200W. what kind of amp is it?
Now, if you wanna go the Car pC route, this is the right forum for you. You can surf gay porn, listen to all your copywright infringed music and use GPS to find your way from one end of the driveway to the other -J187
what makes you think that?Originally Posted by yak8998
Signature: [==||========] 20% complete
I have roughly 150W RMS to play with. Please spare the buy a bigger amp arguments. This is what i have to play with. What im after is a recommendation on a good efficient sub.
Its a response branded amp sold by Jaycar in australia. they are good gear. I have installed about 10 of them in various peoples cars over the years
Cash has a lot to do with your choice. It also depends on the size of the box you want. (read boot space you want to lose) JL's are good. I myself am looking to buy a kicker solobaric due to a small area to put my sub.
I don't want to get into a "this brand is better than that" war but some other brands that may by worth looking at for your power requirements are Pioneer (TS-SW124D), MB Quart(RWE302), Blaupunkt(SW125.1 - 10") and Kicker (05C124).
Box type would be the major factor before choosing the sub.
Ported=Louder
Sealed=Tighter
Sealed may require more power if you have different tastes. I've got a POS Sony XPlod in a sealed box with 200 Watts RMS going into it from a Kenwood monoblock amp and I think it sounds fine.
JL 13w0. Low power needed and still hits hard and can reach 16Hz. Also, needs less than a cubic ft.
50x4, I'm assuming thats at 4ohm. You bridge a pair of channels to 4ohm, power output doubles at 2 (generally), so 100x2 = 200.Originally Posted by Nic
100x2=200? You're bridging it twice? LOL That's like a double bridge... I haven't seen an amp which allows you to bridge 4 channels into 1 channel. In addition, that 4 channel would have to be stable to 1ohm on each channel to allow 4ohm operation when double-bridged.Originally Posted by yak8998
