Results 1 to 8 of 8
Thread: Stock Bose Stereo, Infiniti I30. Wiring question
    Low Bitrate Gene's Avatar
    Jun 2004
    Minnesota
    Hi, I don't know much about car audio. I was able to hook up my 4 door speakers using a wiring harners for Nissan/Bose. I have a four channel amp. I read here that I can connect two speakers to one channel on my amp after measuring resistance. My question is about the rear speaker assy in my car. I opened it up and there is a small amp built-in. There are two wires going from the speaker into this built-in amp. Please see picture 1. Each one then splits into two sets of wires: two green wires on one side and two red wires on the other side.
    If any of you guys have that Bose setup or just know your audio, would you be able to tell what wires I need to tap in to?
    My guess is that I need to tap into red or green, before they get into the stock amp and then connect that to one of the channels on MY amp. Am I way off on this one?
    Thanks a lot for any input on this.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you will most likely need a bose interface. corvette guys have good luck with the 'soundgate' brand/model you could also check out pac-audio
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    chicago, Illinois
    next question is are you going to upgrade your speakers in the future. I'd reccomend doing so, for sound quality, the fact that the bose speakers maynot be able to take the power from a bigger amp, and the fact that those speakers may be 2ohm speaker. You'd only need a bose interface if you were using just a standard aftermarket headunit and keeping the factory speakers. but in the purposes of using a 4 ch amp all you need to do is bypass each amplifier at each speaker.
    To do that, yes you can cut off the amp at each set of wires going to the speaker then run those to the new amp. keep in mind the polarity, I think the red wires are the positive side of the speaker. This has to be done for each speaker. So you have to get behind the door skins of each of the front doors. Kinda risky if you haven't done it b4 or have the right tools
    PROGRESS:
    Jun 2004
    Minnesota
    Thanks. I'll see what kind of bose interface i can find out there. The thing is, I already hooked up my door speakers to my JBL amp. Stock door speakers were easy because they had a wiring harness. That part is OK. It's the rear speaker/sub that I'm not sure about. I understand the polarity. I think it's kind of hard to see, but the speaker in "picture 1" has two red wires and two green wires sticking out of it, going into the stock amp. I've never seen my door speakers, so I don't know what they look like.
    Jun 2005
    chicago, Illinois
    If you read what i said, you cant use the bose interface with a 4 channel amp. Its redudant. You'd end up pulling power from the 4 ch and each speaker. the bose interface is only to be used with an aftermarket headunit. If it were ever possible essentially what you'd be doing is increasing the signal with the 4 ch then decreasing it with the interface, then increasing it again. You'd ended up getting garbled sound from so much transition. or you'd end up burning out the interface, or the bose amp, or the 4 ch. on top of that in some cases the bose amps have a built in equilizer that turns out garbled with the interface. Plus if you kept the amp on the front speakers you'd end up being unbalanced with the rears amped and the fronts double amped.
    As for bypassing the front speaker's amps, they are inside a housing that is held together by a few bolts, take those off then you can access the speaker. the amps in there work the same way as the rears. After you cut off the amp just combine the same color wire the red wires are your positive and the green wires are your negative line. if i'm correct.
    You dont have to listen to what i have to say about this. I mean i've only been installing for about 5 years and i dont have to spoon feed you everything. Ultimately what i would recomend is to scrap the stock amps, and speakers and get new ones. If you even attempt what I think you're gonna try to do, you'll probablly have to do that after you it burn out.
    PROGRESS:
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by pancit175
    I agree with this part, but i think pancit needs to take a midol.
    with the corvette bose system the front door location house the 8" subs and a 3.5" 'twiddler' and the rear has either a 5.25" or 6.5" speakers. the 3.5" and the rear speakers have no bose amp and can be driven by an amplifiier. the sub is what is amped and that is why we need the interface. I am not sure; because i've never used a soundgate adaptor, but if it can take low level inputs you may be able to wire the soundgate to the soundcard and then take advantage of the bose amps for the subs. Then you could get a small amp and power the non-amped speakers (if it is like a c5 corvette bose set up) keep in mind that the impedance of the bose speaker may be 1 or 2 ohms so make sure your amp can handle it. also they can't be driven that hard or they'll distort and fry. one solution would be to swap out the non amped speakers with some nice aftermarket ones (either before or after you fry them ) and keep the rest of the system 'stock' or rip out everything; like i did, and keep it clean with out a bose interface.
    now i'm not an installer and this is pretty c5 specific, but if you research your setup you may be able to apply some of these methods to your own car.
    M10k
    My Car Pc Install
    My Boat Pc worklog
    Jun 2005
    chicago, Illinois
    The bose systems in those series nissan/Infiniti cars, all of the speakers are individually amped.
    PROGRESS:
    Dec 2004
    Los Angeles Ca
    ah. well as you said the best thing to do is rip out the bose system.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  1. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
  2. wiring question?
    By lopan in forum Power Supplies
    Last Post: 01-07-2004, 09:38 PM
  3. Audio Wiring question....
    By jusatry in forum General Hardware Discussion
    Last Post: 01-02-2004, 03:08 PM
  4. A question (or two) about wiring
    By Thartek in forum Power Supplies
    Last Post: 08-07-2002, 08:34 PM
  5. Silly question about Wiring
    By SuperMatty in forum Power Supplies
    Last Post: 02-10-2002, 02:23 PM
