audiocontro unit has two RCA input (L-R) and 4 or 6 output (don't remember)
soundblaster usb has an RCA out (mp3+)
I would suggest to not use audiocontrol and go for a multichannel USB or PCI solution and use a software digital crossover
I will be putting the second carputer in my car soon, but need some help in the audio dept.
I am planning on getting the following, Sound Blaster Live USB, and AudioControl EQX or EQS.
What do you suggest as far as these units.
I am planning on have the computer go into the soundcard via USB.
Then from the soundcard to the EQ, but I dont know the outputs of the SoundBlaste. Will the soundblaster give 3 outputs, or 1? Will they be 1/8" into a RCA? Does the EQ need to be 1 RCA input or 3 RCA input, depending on the output of the soundblaster? Thanks
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Do you suggest something along the lines of this, Terratec Aureon USB.
http://www6.tomshardware.com/consume..._sound-21.html
It connects into the computer via usb, and had 6 RCA outputs, 3L,3R. Its also a good price, at $56 in the house from a authorized dealer.
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
it depends on the EQ and xover settings, not all the drivers allow this kind of advanced tweaking
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
It says minimnum requirements are Pentium III or Athlon 600 MHz, could an EPI motherboard handle such a device?
Ice: Nakamichi MB100, Dynaudio 340, Genesis Dual Mono, JL 12w2, Epic 160
Current Project: Fitting a Cologne V6 to an Eagle SS
yes I think so
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
