Your grounding sounds fine, typical star ground config..
Your power sounds fine, so long as everything gets it's power it should be fine
This smells like an impedance matching issue to me, amps don't usually shut down for much else.. Double check all your amplifier spec pages against your speaker spec pages and brush up on ohm's law. If everything seems to work check the amp against another speaker and the speaker against another amp, barring that i have no suggestions
Good luck!
LinkBack URL
About LinkBacks
