Trouble with the isolator is its AC coupling your head-unit to the amp. Its possible before you used the isolator you were DC coupled. In any case even if you were not, your lowest cut-off frequency would have let the wanted low-frequencies pass through. Now in effect you have a high-pass filter. I'm surprised though that is removes all the bass. Perhaps try a different better quality isolator. Also it might be worth looking at the frequency responses of these devices before choosing a suitable one. They will have some roll-off at the lower end but should be below the audible hearing range, 30Hz or so.
Drdee
LinkBack URL
About LinkBacks
