Results 1 to 6 of 6
Thread: HU AMP AUX only whispers!!! HELP!! Desperate!!
    Apr 2005
    Angry HU AMP AUX only whispers!!! HELP!! Desperate!!
    hello hello hello.
    I am opening this thread because of a wierd problem.
    I have all my dash ready, computer in the back and
    I am using my head unit (Pioneer DEH-P5100R) to amplify the signal
    So I have attached the double RCA Cable to the HU - behind it (there are 2xRCA, hopefully they are the AUX-IN) and drove it to the output of the pc's soundcard.
    Switched AUX on the HU, played a file, I can hear something but it is AS LOW AS A WHISPER, no matter how much I take the volume up!
    I tried bypassing the dualRCA cable and attaching a portable MP3 player to it directly with the same result.
    Any ideas? Pretty please give us some hint I am gonna go crazy on this.
    -M
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    go in to the windows volume control and makesure all the sliders are set correctly, that might have been overlooked
    Aron
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    u sure you got it connected to the right pins on back of the HU?
    Test the pc output with a speaker, make sure its not the pc
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    If it's a DEH-P model, then you probably need the AUX-IN adapter.
    When you say there are 2xRCA, does that mean two RCA plugs, or two PAIRS of RCA plugs?
    Either way, I can almost guarantee you those are outputs. If you have a DEH-P, then you have an IP-BUS connector on the back which should be a blue connector with a bunch of pins. You either need to spend $30 on the adapter for it, or make your own. (http://www.gutterslide.com/ip-bus_hack/)
    Apr 2005
    thank you everyone I am using the wrong input, I need to use the IP-BUS
    so I'll hack it as described here:
    Jun 2005
    chicago, Illinois
    You never want to put an input to the rcas in the rear unless you know that those are aux. The pioneer models do not have aux input readily available and require additional cables or moduals. If you do put the input to the RCA plugs that are preouts, they will give some sound through the hu as described as a whisper, but it will also burn out the hu because of backfeed.
    PROGRESS:
  1. How to run AUX sound through Clarion HU
    By Xterrian in forum General Hardware Discussion
    Last Post: 12-13-2005, 11:17 PM
  2. volume control using aux in hu
    By titaniumkingpin in forum Car Audio
    Last Post: 03-01-2005, 03:00 AM
  3. Amp or HU dilemma
    By paul167 in forum Car Audio
    Last Post: 11-03-2004, 06:45 AM
  4. Replies: 1
    Last Post: 09-06-2004, 01:52 AM
  5. PC -> Amp and HU - Amp question
    By Nokia6600 in forum Newbie
    Last Post: 03-24-2004, 05:42 AM
