Results 11 to 20 of 25
Thread: $25 Headunit whines, can anything be done?
  1. #11
    Jun 2005
    Well I grounded the back of the headunit to the car and nothing changed.
    The way the ground is set up, I have the negative wires of each speaker as well as the ground from the stereo connected to the black wire from the wire harness. They are all connected in the same place, so I don't know how there could be a difference in potential. It is likely just this stupid configuration that is causing problems with electrical components in my car. It is also very hard to ground something directly to the chassis since almost everything is made out of plastic.
    I think I'm going to throw this out and buy this instead.
  2. #12
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    If your power wires run near your speakers wires, they could induce noise.
    Want to:
  3. #13
    Jun 2005
    Quote Originally Posted by Bugbyte
    Yes, they do, but they also do in the stock headunit which is noiseless, and there's really nothing I can do since all wires are basically clumped together in the same place, especially where they enter the headunit.
  4. #14
    Jun 2005
    chicago, Illinois
    Thats usually only true when you have an amp that has inputs that line up with large gauge power wires and the amp picks up that irradiated noise and then amplifies it. In the case of a hu stock or aftermarket, the lines going to the speakers are not going to be amplified again.
    PROGRESS:
  5. #15
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    What do you expect from a 25$ head unit that looks nice. They have to cut on quality somewhere.
  6. #16
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by pancit175
    Good point. I had this issue, which is why I posted it, but on second thought, it was my RCA's into the HU aux in, which is similar to what you are describing.
    Never mind.
    Want to:
  7. #17
    Maximum Bitrate falconey's Avatar
    Feb 2004
    Atlanta
    Quote Originally Posted by dimva
    Sorry to say, but this is your problem right here.
  8. #18
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    no matter what you buy if you hook it up like falcony quoted it wont work.
    I suggest you start looking into online tutorials on how to wire a stereo system
  9. #19
    Jun 2005
    Quote Originally Posted by antimatter
    OK, but the diagram says this is how you do it. Or perhaps I'm wrong?
    Check out the diagram, it shows both (-) speaker wires and the ground from the stereo connected to ground in the same place. Diagram is attached because my server seems to be down at the moment.
    If I'm misinterpreting it, please tell me how I should do it. Read my original post, I've already searched for information.
  10. #20
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Just to clarify - you have the negative speaker wires connected to the black ground wire coming out of the radio, right?
    THEN, the black ground wire is grounded to the car chassis, right?
    Want to:
  1. Headunit (Linux/Windows CarPC frontend) + initial screenshots
    By NoPistonPC in forum Other Cool Front Ends
    Last Post: 08-24-2007, 03:57 PM
  2. Replies: 9
    Last Post: 12-09-2004, 01:34 AM
  3. How to send sound to headunit? or system?
    By SilverGT in forum Car Audio
    Last Post: 09-24-2004, 11:41 PM
  4. help or suggestion about relocating headunit.
    By cyberpotato in forum Car Audio
    Last Post: 06-09-2004, 09:03 PM
  5. What`s your favorite headunit....Aux in
    By PORTUGAL in forum General MP3Car Discussion
    Last Post: 11-22-2003, 10:30 AM
