Results 1 to 10 of 10
Thread: no sound from speakers
    May 2003
    now before you say it... I have read all of the FAQs multiple times and checked over my wiring at least 5 times.
    now my carpc works just fine, I have it hooked up into my vehicle and I can hear the sound output when using headphones. but when I plug in the stereo to rca adapter plug for the amp no sound comes out of the speakers. The amp IS turned on, I am sure of this. There is a short period of static coming from the speakers when the amp is first turned on and the power LED is lit up. I cannot figure out what is not working correctly unless the amp itself has not been working from the start.
    Anybody have an idea of why I am not getting any sound from my speakers?
    Mar 2005
    NYC
    Well if you checked your wiring 5 times...check the amp at least once.
    May 2003
    what is that supposed to mean?
    Apr 2005
    Queens, New York
    are you using a usb sound card?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    May 2003
    m10000 onboard sound, it has to be something with the amp, not the computer because I can hear the music just fine with headphones but nothing once i plug in the amp.
    Apr 2005
    Queens, New York
    get different sound card. You mobo SC wont give good sound. Get an external SC. It would be much better!
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    May 2003
    thanks for the advice, but I would like to actually be able to hear the sound from my speakers first!
    Apr 2005
    Queens, New York
    are you sure the plugs (adapters) are phono and not mono
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Constant Bitrate anitanium's Avatar
    May 2005
    Vancouver, BC
    was your amp working before?
    maybe in a previous car stereo setup?
    maybe you have to set the gain? the voltage signal from the computer isn't very high
    [||||||||||||||||||||] - final touches
    SUPER 7" VGA w/ TS
    Toshiba Satellite 3000
    P3 850
    256MB
    30GB
    Geforce2 Go
    DVD
    Orinoco 802.11b PCMCIA
    nlite WinXP 350MB installed
    RoadRunner
    iGuidance 2.1
    Holux GM210 GPS
    Xantrex Xpower 300
    May 2003
    well I just bought the amp so I have not tested it before but I will try to do that in the next day or two.
    I adjusted the gain and nothing could be heard from the speakers.
    I am sure the plugs are phono
  1. Getting sound to car's speakers....
    By futuresweets10 in forum Car Audio
    Last Post: 10-15-2004, 01:46 PM
  2. stereo sound with 4 speakers question
    By crashwg in forum Car Audio
    Last Post: 05-25-2004, 07:53 PM
  3. Replies: 9
    Last Post: 11-10-2003, 02:21 PM
  4. Another pc sound -> car speakers question
    By Juz in forum General Hardware Discussion
    Last Post: 10-17-2002, 12:47 PM
  5. Replies: 3
    Last Post: 07-30-2001, 09:25 PM
