Results 1 to 6 of 6
Thread: How would I hook this up
    Apr 2005
    Queens, New York
    ........to a Sound Blaster Audigy 2 NX USB?
    I see that There is only a Line IN / Line Out / And Sub
    WOuld it Hook up like this :
    Amplifier -------> EQ (Line IN)-----> EQ Line Out ------>Sound Card (Line In)
    How would i hook it up?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    Sound Card Output------->EQ Line In----->EQ Line Out------->Amplifier Input--------->Out from amp to speakers
    Apr 2005
    Queens, New York
    i dont have an amplifier input. All i have on my amp is:
    Front (L/R) / Rear (L/R) and subwoofer
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    Jun 2004
    Central California
    A few alternative solutions:
    - If you'd be using this EQ for your front speakers then you'd buy another EQ for your rear speakers (providing you'd have a pair in the rear of the car)
    - If you'd be using only this one EQ then you could split the RCA output from EQ to accomodate both front & rear inputs of the amp
    - You could also just use this EQ from your front speakers and not the rear ones. For this you'd just split the output from the SoundBlaster; a pair would go to the EQ which then would go to the front input of the amp. While the other pair would go to the rear input of the amp.
    EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
    Jun 2004
    Central California
    Didn't see that you have another input for subwoofer; for the subwoofer input, you'd need to split one of the channel also.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    For the subwoofer, you'd need a splitter on the subwoofer output of the EQ.
    So output of soundcard to EQ, split off the EQ to front/rear, and split of the subwoofer output to the input of the sub amp (As most of them require left/right)
    The subwoofer output on the bottom is controlled by the dials with the black highlight behind the frequencies on the top.
  1. Replies: 1
    Last Post: 04-10-2005, 06:24 PM
  2. Replies: 1
    Last Post: 03-23-2005, 12:41 PM
  3. PCI Extension and Graphics Card Hook UP
    By alienjj in forum General Hardware Discussion
    Last Post: 03-14-2005, 11:10 PM
  4. can I hook this up safely ?
    By E-nigma in forum General Hardware Discussion
    Last Post: 12-09-2003, 12:31 PM
  5. Where to hook up to read OBD?
    By Ritalin Kid in forum General Hardware Discussion
    Last Post: 08-17-2002, 10:12 AM
