Results 1 to 3 of 3
Thread: Adding subwoofer to 2ch output?
    Maximum Bitrate KyleYankan's Avatar
    Mar 2005
    Hey everyone. I have a quick question. I want to get a sub-woofer that basically goes "BOOM". Yeah, I know not much. ;-)
    I'm looking into getting the speaker/box from my brother or eBay, but I have 1 problem. Do I just throw one of my channels into each of the subs? Is there a way I can make it only react to the lower frequecnies (a capacitor or something?)
    I want to be able to use this through the remaining channel on my amp (rear speakers are only using 1ch), with only 1 big ol' sub. Cost is a big issue for me. Should I just go get another amp for subs? And if so - how do I connect it to the car-puter? Can I just sue the standard channels with a splitter? I have no room for expansion (using an ePC), so the 2-channel audio is all I got.
    Thanks in advance for all your help.
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    Quote Originally Posted by KyleYankan
    Is there a way I can make it only react to the lower frequecnies (a capacitor or something?).
    Thats called a crossover or a filter. A lot of amps have a high pass or a low pass filter on each pair of channels, this ramps down and cuts the frequencies below (or above) the level you set on the dial. For a sub you want a low pass filter with the dial set somewhere below 300Hz (hard to be exact, depends on your other speakers, your car, you speaker etc)
    I dread to think how you are getting your rear speakers from one channel of an amp- you dont like stereo I take it? While a sub would work from an unused channel you wouldnt be able to use any onboard filters, youd need a separate crossover. It would be best to get a dedicated amp for it.
    a splitter would work yes
    Mar 2005
    Actually I think the rear speaker are wired like that. Whenevr I hooked up either of the rear speakers (right or left channel) they bouth made noise. :-/
  1. dual vioce coil sub/amp wiring
    By hotponyshoes in forum Car Audio
    Last Post: 12-24-2007, 01:20 AM
  2. Aux-in Analog audio... will it output from the SPDIF on mainboard?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-07-2005, 10:57 PM
  3. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  4. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
  5. Car Alarm Aux output and Shutdown controller
    By MatrixPC in forum Power Supplies
    Last Post: 05-09-2004, 08:36 PM
