Results 1 to 3 of 3
Thread: Powering Sequence
    Feb 2005
    Powering Sequence
    Correct me if I'm wrong..(I probably am) so I don't get amp popping I want the amp to turn on after the computer right?? so would it do the job to wire the rem to a molex.
    Also when do I want the amp to power off?? I'm guessing after the computer is off,,(just to make things a little more difficult) so would it work to put an inline switch on the rem to accomplish this??
    And the only solution that I've found with is to get a delay...which I don't really want to do.
    Jun 2005
    Kent, England
    i'm also curious about this, i think you got the right order for startup but you want the amp off before the comp on the shutdown, not completely sure though
    be handy if it could be taken off molex??
    Takes it in the Rear kevinlekiller's Avatar
    Dec 1969
    Where the penguins and polar bears live.
    Maybe use the molex 12v with a relay and inline with a capacitor. So when the computer is off power will still go in the amp remote from the cap.
  1. Powering a cdrom via "monitor" psu output?
    By mattdisaster in forum Power Supplies
    Last Post: 12-24-2004, 09:56 AM
  2. A solution for powering 12v stuff inside
    By zootjeff in forum Power Supplies
    Last Post: 12-17-2004, 07:21 PM
  3. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 04:19 AM
  4. Powering Lilliput touchscreen
    By Pabs in forum LCD/Display
    Last Post: 05-21-2004, 05:29 PM
  5. How to go about powering on.off Car PC
    By Speg in forum Power Supplies
    Last Post: 03-16-2004, 08:07 PM
