Results 1 to 9 of 9
Thread: Where is your main fuse located?
    Dec 2004
    Where its windy
    I have a 4ga wire running into my trunk to power my inverter. The fuse is currently located in the engine bay but there really isnt much room there to mount it properly. Where do you guys have your main fuse located?
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    You're going to want your main fuse as close to your battery as possible. Even if the mounting options are limited.
    Constant Bitrate CapitaineFritz's Avatar
    Feb 2005
    Laval, Quebec (Canada)
    Quote Originally Posted by ACHIEVER
    +1
    Via Epia M10000 / 512 DDR / 10gigs 3.5 HD / M1-ATX / Innovatek 7" TS Screen
    Trunk fiberglassing in progress...
    Need GPS / Aux Input / WiFi
    My Corolla Computer
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Yeh, that's were I'm putting mine. I originally wanted to hook up into my fuses in the engine, but its easier not to do that
    Maximum Bitrate boomintrac's Avatar
    Apr 2005
    2hr west of Chicago
    rule of thumb within 18inches
    Jun 2005
    chicago, Illinois
    Quote Originally Posted by boomintrac
    that way if there is any break in the insulation after the fuse the fuse will break protecting the remaining electronics that is hooked up to the battery. The main reason for the fuse, other than the instance when a component is shorted out or overdriven, is to protect the wires. If a wire is not fused, in the case of a wire shorting out, the wires will cause an electrical fire.
    PROGRESS:
    Variable Bitrate SickVette's Avatar
    May 2005
    Wesley Chapel, Fl
    pancit almost got it. The fuse on your main power line is not to protect the electronics. It is to protect the automobile. Main power lines are generally large gauge wires. Those cables can supply enough current to cause a fire. If the cable is shorted to ground and there is no fuse the car can and often does go up in flames. Also if the car has two batteries ..one front and one rear...the power line connecting them needs to be fused at both ends.
    The 18" rule of thumb was started by IASCA a few years back. They determined somehow that 18" from the battery is close enough. Personally I install my fuses as close to the battery as possible...often with in a few inches.
    As for mounting...get creative. I use alot of aluminum to make mounts. You can get pieces of 2x2 angle from Home Depot and easily make a mount. That is just one way.
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    my fuse is 3" from teh battery, ontop of the fusebox, there should be SOMEWHERE that it can go.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Mar 2004
    Bismarck, ND.
    Keep it as close to your battery as you can. If your mounting options are that limited you can get a battery terminal that has a builtin fuse on it.
    http://www.cardomain.com/item/ROCCPBCMAX1
    1992 Buick Skylark - 3.3L V6
    Alpine CDA-9805 Headunit
    Alpine SPS-690A Rear 6x9 Speakers
    Alpine Alpine SPS-460A Front 4x6 Speakers
    Crossfire VR1000d
    Crossfire BMF W15D x2
    100 Amp Alternator
    Montana MECA M2 and DB2 Points Leader
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 11:01 AM
  2. Main menu with Video play on 2nd LCD
    By dougmorgan99 in forum Road Runner
    Last Post: 09-05-2005, 12:27 PM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. Xenarc fuse and power help required
    By Scouse Monkey in forum LCD/Display
    Last Post: 02-18-2005, 03:45 PM
  5. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 05:59 PM
