Results 21 to 30 of 36
Thread: engine wine know how its there but can't get rid of
  1. #21
    Jul 1999
    Birmingham, Alabama (War Eagle!)
    Quote Originally Posted by kirbycope
    its the inverter, ditch it and get an OPUS, problem solved.
    problem NOT solved. i have an opus 150 and a properly grounded amp and pc and i too have the dreaded alternator/engine whine.
    i like leslie's idea of having a grounding block, why not have one, since most of us have a power distribution block too. it makes sense.
  2. #22
    Jan 2005
    maybe i can help you out i just got rid of this problem on mine ok you said the pc is using the aux in port on the headunit if you unplug the audio cable fromt eh soundcard does the whine stop?
    If you turn the PC off is it still there with the headunit one? at a high volume?
    and next was my problem I used a plexiglass sheet to mount my motherboard well needless to say the brackets on the plexiglass were some how causeing a whine I insulated all the connections and bolted everything back down and it stopped.
    oh and I am running mine off of a old 400w generic inverter
  3. #23
    Jun 2002
    Malaysia
    yonu
    what do you mean "brackets on the plexiglass" ?
  4. #24
    Jan 2005
    to secure the plexiglass plate from moving and vibrating mine is mounted to two alluminum brackets that are bolted to the body of the car and the motherboard was mounted to the sheet using 6x24 machine screws and nylon spacers so i simply insulated both using electrical tape and put rubber gromets on the screws and it did the trick no more whine
  5. #25
    Jun 2002
    Malaysia
    Yonu
    I think a picture will tell a thousand words.
    Thanks though
  6. #26
    Jan 2005
    ok will get one taken in a bit
  7. #27
    Jan 2005
    ok here are the pics i will take some of the back or the sheet a bit later this evening after the temp goes down some
    oh and where the screws are in the mounts there is a rubber oring on the screws on both sides of the metal brackets
  8. #28
    Low Bitrate ste1806's Avatar
    Nov 2003
    derbyshire u.k
    part of your problem could be the low voltages the soundcard outputs, you could try a pre amp. i use a pheonix gold pro line driver that ups my voltage from 2.2v to 8 volt, solved my problem with whine instantly. Also before i got the pld i wrapped my rcas in a couple of layers of foil, this helped a bit also added abit more shielding to the cables. HTH
  9. #29
    Jul 2005
    Quote Originally Posted by ste1806
    where did you get the phoenix gold line driver?
  10. #30
    Nov 2003
    derbyshire u.k
    i purchased it from ebay
  1. Replies: 3
    Last Post: 06-02-2005, 07:08 PM
  2. Noob Questions: Turning Off Media Engine
    By FiReToY in forum Media Engine
    Last Post: 01-01-2005, 07:36 AM
  3. Replies: 4
    Last Post: 06-29-2004, 08:20 PM
  4. Adding text-to-speech functionality to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 04-19-2004, 01:38 AM
  5. Useing GPS with Media Engine and other Question
    By Twizted in forum ME Archive
    Last Post: 01-10-2004, 06:36 PM
