Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: engine wine know how its there but can't get rid of
  1. #31
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    He can test if its the inverter by parking close to his house and runnig a cable from the house to power the pc, but it should not be the inverter if it goeas away with the ignition off.
    Inverter should be connected with 2 thick cables direct to battery and dont share them with anything else.
    Try taking all gounds to a single bolt through the vehicle floor, and taking power for all your equipment form the battery(+) terminal.
    I have had whines were the amps where connected to battery(+) but the HU was connected to the cars electrical system etc, I would be looking at the amps/HU.
  2. #32
    Jul 2005
    Brisbane, Qld, Australia
    I just replaced my cheapo, no-name head unit with a Pioneer unit, and I'm getting a whine (alternator, I think, too high-pitched for ignition whine).
    I'm going to try connecting the battery power for the HU into my amp supply cable instead of the stock HU wiring.
  3. #33
  4. #34
    Newbie treydogg's Avatar
    Oct 2005
    did you try a power conditioner?
    AMD 64Bit XP 3800/1 gig ddr-400/8" lilliput TS/200 gig SATA drive/sprint megillin wireless/pharos 360GPS
    "I swear to God officer, I use it for gps!"
    http://www.treydogghour.com
  5. #35
    Newbie edraws's Avatar
    Nov 2005
    Canada
    I have a Pioneer MP4600P and I'm installing an xbox for my multi-media device.
    This whining problem seems almost specific to Pioneer head units.
    Get this...
    If I plug in my xbox even with it turned off into my inverter I will get a high pitch whine if the engine is running or not.
    If I unplug the xbox the sound is immediately gone.
    NOTE: I don't have my CD-RB20 auxiliary adapter yet.
    So what I'm hoping is when I hook up the adapter it will eliminate the whine because it is powered and needs to be grounded as well.
    But once again let me state, it's has a whine with the xbox plugged in whether on or off, engine running or not.
    I haven't tried direct house power yet, so trial and error will tell once I get my adapter.
  6. #36
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    Try testing grounding resistance with a multimeter to where you ground your electronics.
    Have you grounded your altinator in the cars engine bay?
    Look by the battery in your engine bay. See the ground wire connected to the car body to the (-) terminal? If that is a 10 gauge wire rusty wire, yank that out and put some 4 gauge and sand the contact points where it connects to the body.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  1. Replies: 3
    Last Post: 06-02-2005, 07:08 PM
  2. Noob Questions: Turning Off Media Engine
    By FiReToY in forum Media Engine
    Last Post: 01-01-2005, 07:36 AM
  3. Replies: 4
    Last Post: 06-29-2004, 08:20 PM
  4. Adding text-to-speech functionality to Media Engine
    By skippy76 in forum Media Engine
    Last Post: 04-19-2004, 01:38 AM
  5. Useing GPS with Media Engine and other Question
    By Twizted in forum ME Archive
    Last Post: 01-10-2004, 06:36 PM
