you try grounding the HU and computer to the same point?
Hi all,
First of all I have searched the forums tried every possible solution I have found on this forum with no luck so here I go.
I have a very common engine wine noise problem.
first of all power wires & rca cables are separated
all computer cables are separated from power and speaker & rca cables
using a head unit aux in (pioneer DEH-P960MP head unit) for computer
external SoundBlaster soundcard
shuttle pc
1 4ch amp
1 mono amp
300 watt inverter
If I do not ground any part of the computer I.E. The case,power supply, motherboard etc I get a loud "buzzing" interference noise. At that point I do not hear any "engine wine" noise that is consistent with the rpm's of the engine. if I ground the case,motherboard,power supply or even all of them the "buzzing" noise goes away but then comes the "engine wine" noise.
(tried single & multiple grounds to different points on the computer parts and different grounding points in the car.
with sizes from 14g to 4 ga wire but does not help)
also tried ground loop isolator by the soundcard and even going to the amps with no luck.
I am not sure how to get rid of the engine wine noise.
I know where its coming from because when I ground the case its starts then, but I do not know how to get rid of the wine.
any ideas
Michael
Thanks for your response.Originally Posted by greenman100
I did try that with no luck.
Thanks Anyways.
Any other ideas
Michael
does this just happen with the PC, or is this an issue with the amp? I know a friend who's amp does this....and i believe its an internal issue
PC Components:
My work log
Hi,Originally Posted by Peoples
Thanks for the response
If I have the computer off and just play a cd in the head unit there is no" wine"
Also if I unplug the computer from the inverter there is no "wine"
If I have the inverter running with the computer not pluged into there is no "wine" from the inverter.
It only comes from the computer when I ground it to get rid of the "buzzing" noise.
Any other ideas
Michael
two things, did you ground the inverter?
secondly, make sure nothing is shorted on your motherboard, make sure you arent using any of foam or anything to cussion the motherboard or anything
PC Components:
My work log
what are you talking about, the 12v side of the inverter HAS to be grounded ot work
and if you're taking the 120v side he said he grounded the case whoich is cnnected to the PSU which is connected to the 120v side of the inverter.
have you tried running direct fromt he computer to amps?
Hi,the inverter is not grounded besides the (-) terminal on the inverter because the case of the inverter is plastic.I am not sure if i open it up where to ground it to.Originally Posted by Peoples
also would that make a difference?
because like I said I can have the Inverter running by its self and there is no " wine"
The motherboars is screwed down to the metal case with out any cussion.
Michael
i'm talking about the case of the inverter, the case might have a different ground. But also if the inverter and the amps dont have a common ground that could be an issue as well
PC Components:
My work log
have you tried running direct fromt he computer to amps?[/QUOTE]
No I have not tried that.
Will try that Tomorrow
Michael
