If you did ayou'd see that any sound card has 1/8" phono jacks. What you need to do is get cables that go from 1/8" phono to RCA stereo. You'll also need to extend those RCA lines with RCA barrel connectors(if both ends are male RCA connectors) and additional length of RCA lines for each set. Then you can attach those to your aftermarket 4 ch amp.
LinkBack URL
About LinkBacks
you'd see that any
or it should be illustrated on the card
