What you have is the wire harness for your car.
It takes all the wires every stereo needs, and puts them into a nice big plastic plug. Thing is, that plug only fits one thing, the stock head unit.
You need to buy the wire harness adapter thingy for your model car. It will plug into the plug from the car and then give you all the bare wires to hook into the bare wires you have with any head unit or cd changer etc.
I dont really understand your entire post so maybe you need to clarify.
If what you want is to replace the radio in your car with a new one, do what I said.
If you want to hook up a cd changer to your existing radio, you cant do that the way you describe. You need to use RF cd changers that use the radio in your car to transmit the CD changer instead of hard wires and direct control.
Sounds like your car had an OPTION to have a CD changer in it, thats what the button "labeled CD changer" was for. Not for ANY CD changer.
Grounding L/R inputs? ummmm what?
M or A? Again what?
LinkBack URL
About LinkBacks
