Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: A Few questions about Digital Sound with a Carpc
    May 2005
    After my search's and you carpc'ers answering my questions. It seems that playing music through a Digital connection using the motherboard or the soundcards SPDIF OUT is the way to go for SQ in the CarPc. that said and done I will be powering my 2 jl w6v2 12inch and my cdtaudio es620 component's through a digital connect. I wanted to know if a linedriver would be useful in this setup below.
    carpc--->audiobahn dac----->audiocontrol linedriver----->amps is that pointless or does the audiobahn dac boost the voltage? im driving to see if it's worth it to spend this money to get digital sound..you know i can care less about movies..i just want my cd's to play "the same or better" as they do with my currently alpine h/u....I hear spdif is the only way to go..also are their any line drivers that have digital in and analog out? let me know as the audiobahn is $300+ and the alpine pxa-h701 is like $375..I see a ads-4000 for like $100 that has digital in's and analog outs..what would be the downfall in getting the ads? thanks for the help.
    most important question..are their line drivers that boost voltage and have digital input and analog outputs. thanks!!
    _
    Mar 2004
    Little Elm, Texas
    audiobahn dac?
    do you have a link to this unit that you speak of?
    (in general, if it has audiobahn on it, it's not going to be good for SQ....and you said you wanted SQ.....)
    the alpine unit that you speak of is JUST the processor, you will need the display if you want to be able to tune the unit at all....
    do you have a link to the ADS-4000 as well?
    Jan Bennett
    Apr 2005
    Queens, New York
    What is the model number of thE Alpine processor?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
    May 2005
    alpine PXA-H701 is the model #
    AudioControl Matrix 6-Channel Line Driver can i use this?
    Ads 4000 can i use this?
    http://www.midiland.com/proddetail.a...r=60&category=
    and here is the audio bahn!!
    http://cgi.ebay.com/ws/eBayISAPI.dll...Name=WDVW&rd=1
    please help me..I want to run digital..i will be going from my spdif output on my motherboard to some type of digital IN using optical cables..then from that device, to my AMPS..the big question is..WHAT IS that device? i need a device that decodes the digital and also rase the voltage if possible since I hear that is a much..let me know people.
    Apr 2005
    Queens, New York
    The display controller for the Alpine Processor, is it just the faceplate or does it have to go into a din slot? What I mean is, does it take the actual spot or you head unit or is it just the face plate that can be mounted anywhere?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    it's just a face plate, it's baout an inch and a half thick...it's model number is RUX-C701
    I mounted mine in my center console....you can go to my install page on my web site in my signiture to see more about it
    Jan Bennett
    Apr 2005
    Queens, New York
    Quote Originally Posted by Red GTi VR6
    Thanks Alot. Now how easy it this to hook up? I still need my Audigy 2 Nx rite? Do i just take the SPDIF out from the Sound Card and hook it into the alpine?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
    _
    Mar 2004
    Little Elm, Texas
    I don't know about the 4000 since it's ment for home audio...not sure it would handle the car environment all that well...
    as for the audiobahn...ick....I'm not going to remomend anything audiobahn....I can't stand their stuff
    might consider something like this??
    http://www.arcaudio.com/arc-05/processors/peq.htm
    or one of their other products....
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by Cheekz185
    no need for the sound card if your mobo has SPDIF out
    it's really easy to hook up, but the tuning can be a bit tricky if you don't know what you are doing....it does come with a mic that will get an approximate tune for you...
    it's honnestly the best piece avaliable for the money, hands down....I know a LOT of people on here will agree with that
    Jan Bennett
    Apr 2005
    Queens, New York
    I have an M10k and it doesnt have SPDIF out...So I think i still need the Audigy2 NX. Do I use the Optical Out or IN or do I use the SPDIF Out?
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    OPUS ITX PC Case
  1. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
  2. HOW TO: Get sound from PC to Car Stereo / Amp
    By ppgt94 in forum The FAQ Emporium
    Last Post: 05-31-2005, 05:20 PM
  3. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  4. Pro Logic vs digital surround sound
    By lookinco in forum Car Audio
    Last Post: 08-28-2004, 10:29 AM
  5. Newbie, but surely no Dummie
    By crazybat in forum General Hardware Discussion
    Last Post: 12-25-1999, 09:41 AM
