should have a source button that will cycle between radio cd then aux assuming you have it conected right. this is how it works on my sisters pioneer hth![]()
i have had a problem for some time getting my Pioneer DEH-P3600 to switch to AUX so i can hook up my aux input for my iPod. I have everything set up, but nothing is working. I have not been able to switch over to AUX on my Pioneer and have no idea how since i don't have the manuals or anything.
If anyone could help me out with my predicament, I appreciate it.
well, i figured it should, but i haven't found the option. I plugged the adapter to the AUX out in the back of the Pioneer and that was it, assuming that the Pioneer would detect that i had a plug in...am i doing anything wrong as to why it isn't detecting that i have the AUX plug in?
The link to the product manual for your HU.
http://www.pioneerusa.com/pio/pe/ima...0DEH-P3600.pdf
first turn the unit off
press and hold the "f" function button and hold
the unit should enter setup mode
press the function button repeatedly until "aux " appears
then use the up-down buttons to turn it on or off
alright, i'm off to try it out. thanks for the help so far!
Thanks, it worked! I appreciate all the links and run-throughs. i would had been lost without the help!
You should be able to rename the AUX to IPOD or CARPUTER![]()
