Results 1 to 10 of 10
Thread: Rear speakers not going :(
    Constant Bitrate samael's Avatar
    May 2001
    new zealand
    Hi all
    I just purchased a 1992 Honda Accord, but the rear speakers dont seem to be going. They are there, I checked Swivling the 'fad' knob to the rear merely turns off the front 2 speakers, the 'balance' knob works as expected.
    I should mention that everything looks factory, the headunit has Honda all over it, the speaker covers are origanal, and the screws around the dash were so tight that I am sure no one has removed them since 1992
    So anyway I thought I would do some troubleshooting, see if I cant figure out whats going on. After about 2 hours trying to figure out how to remove the head unit, and another 45 minutes, upside down, actually removing the thing (who would've thought 2 bolts would be so hard to remove O_o) I was ready to start troubleshooting.
    So I unplug the headunit from the big fat plug with a bunch of wires coming out of it, open the boot to find out what colour the wires on the rear speakers are, then whip out my multimetre.
    Heres where the questions start :
    A: Whats the plug thing called? The one that plugs into the headunit, and has a bunch of wire coming out, power, aux, speakers etc....
    B: Does anyone know a resource that will inform me of the meaning of the colours of the wires? I can't seem to conjure up a search string that will coax the information out of google, but I dont know the name of the big fat plug thing, which may be half my problem.... I can guess which wires are the speakers, given that I can easily see the rear speakers wires.
    C: The left and right wires come from the speakers, disappear into the car, and reappear shethed in black tape stuff, entering the big fat headunit plug. If I was to put my multimetre into ohmmetre mode, what would I expect to see when I put the contacts across the end of the wires? I didnt see a value for the speakers I was testing, that is, the value stayed at 1, which is the value that the metre reads when the contacts are not touching anything. I figure that the whole circuit is a bunch of wire, and a coil going around a magnet, so that means I should get some resistance, correct?
    D: What am I going to if, for some reason, the speaker wires dont make a whole circuit? The headunit is fine and the wires are bung? What I mean is how am I going to track down where the wires run through the car? Is there a common way that this is done, or are all car different so just because your car routes the wire through the roof doesnt mean mine will?
    I am not afraid of hard work, but I would prefer to work a bit smarter. Blugening my head against the bottom of the steering column, and the underside of the glove box was necessary, because car stereo removal instructions on the internet seem to be as rare as hens teeth. Also, it is winter here in NZ and daylight hours after work are minimal
    I am perfectly happy with the factory stereo (that must be blasphemous to some members ), and I dont believe in paying someone to do something that I am perfectly able to do myself, espescially when there is learning involved. Thats why I didnt just buy a new one, and have it professionally installed.... Although with every 2 cm twist of my socket set wrench thingy while my head was stuck under the brake pedal, I was wishing I had >8)
    My previous cars have all been "drive them into the ground" models, so I just ripped and cut away with reckless abandon when installing audio equipment. If it didnt fall out, and it all worked, then that was fine with me
    stupid quote # 1 : "i dont do drugs , i only ever smoke pot when i'm coming down" , Me , 6 september , 2001.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    A. Normally called ISO connectors if it is standard. Although you may have a Honda OEM connector to ISO adapter.
    B. Red +ACC, Yellow +12V, Black (-) Ground, Multicoloured pairs usually with a stripe on one are the speakers. Orange switched +12V (ie when the unit is on it switches 12V normally for automatic aeriel, Blue is usually a muting lead for handsfree car kit etc.
    C. resistance should be about 4 ohms for normal car speakers but can be anywhere between 2 and 8.
    D. The wires would normally go either down one side or through the middle. However some cars have slightly false floors and the cable runs are under that. You will just have to trace them. Try asking same question on a Honda forum, there will be someone there who has the same car and will have done it.
    May 2001
    new zealand
    Quote Originally Posted by Enforcer
    Excelent, thanks
    Coolies!
    True. hondaforums, here I come
    Maximum Bitrate Dragonknell911's Avatar
    Aug 2004
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    OK is this a 2 door or 4 door and does it have the Bose system?
    Any way here are the wiring table for the 1992 3 door coupe
    Battery WHT + (+) IGNITION SWITCH HARNESS
    Accessory01 YEL + (+) IGNITION SWITCH HARNESS
    Ground BLK - (-) RADIO HARNESS
    Illumination RED/BLK (+) RADIO HARNESS
    PowerAntenna YEL/WHT (+)
    RADIO HARNESS FrontLeftSpeakerPos BLU/GRN
    FrontLeftSpeakerNeg GRY/BLK
    FrontRightSpeakerPos RED/GRN
    FrontRightSpeakerNeg BROWN/BLACK
    RearLeftSpeakerPos GRY/WHT
    RearLeftSpeakerNeg BLU/YEL
    RearRightSpeakerPos RED/YEL
    RearRightSpeakerNeg BRN/WHT
    Amp IF BOSE AT EACH SPK
    Jun 2005
    Jupiter!!!!!! FL.
    For the 92 Accord 4 door sedan
    PowerAntenna YEL/WHT (+) RADIO HARNESS
    May 2001
    new zealand
    Quote Originally Posted by accentsound
    4 door
    Um, I dunno....
    Cool thanks, but aren't those two lists identical? I wasnt aware accord came out in a 3 door coupe....
    Whats the difference between the 'IGNITION SWITCH HARNESS' and the 'RADIO HARNESS' ? What does that terminology mean?
    May 2001
    new zealand
    Well it turns out the speakers are bung, so I replaced tham with some cheap sony xplod's.... Thanks for everyones help
  1. How to connect rear speakers?
    By crispvx in forum Newbie
    Last Post: 08-19-2006, 10:17 PM
  2. Change Rear Speakers Lexus 95 ES 300
    By pty_rosie in forum Car Audio
    Last Post: 04-02-2005, 01:48 PM
  3. rear speakers?
    By kuwupt in forum Car Audio
    Last Post: 11-08-2004, 08:57 PM
  4. Replies: 12
    Last Post: 10-28-2004, 07:44 PM
  5. noise from rear speakers, please look at video
    By sanbas in forum Car Audio
    Last Post: 09-25-2004, 08:46 PM
