Results 1 to 4 of 4
Thread: Popping Noise
    Aug 2005
    Pennsylvania
    Popping Noise
    In my carputer im running and M1-ATX power supply. It has a built in amp remote switch that turns on the amp after the computer starts. It works fine but I still get a popping noise from my speakers when windows boots up. The amp turns on right before windows is done loading. The problem with this is that I had another amp hooked up and it worked fine before. I didnt move any wires or anything like that, I just took out the old amp and put the new one in without moving any wires around. Everythings grounded correctly so I know its not that. Any suggestions?
    Nov 2004
    I had a similar situation with turn off pop with my first real car audio setup. Everything worked fine but when I threw my Orion Concept 97.2 EQ in the mix I rad into trouble. What I ended up doing is put a small 400uF capictor and a diode in line with the remote wire before it went to the amps/eq which elimited the problem.
    You're having the opposite problem however after some googleing it seems the same thing could be used to prevent turn-on pops and delay the turn on of that device.
    Dave Navone has one you can buy for 16.00 at http://www.autosound2000.com/ or there seemed to be a schematic at crutchfield.com where you could build one if I remember correctly.
    Aug 2005
    Pennsylvania
    Cool thanks
    Newbie pasic's Avatar
    Nov 2005
    Canada
    volum3rider, did that work for you by the way?
  1. Noise (from engine and other sources) HELP!!!
    By sstylos in forum Car Audio
    Last Post: 09-20-2005, 01:41 PM
  2. Troubleshooting: NOISE
    By RedGTiVR6 in forum Car Audio FAQ
    Last Post: 03-26-2005, 11:31 AM
  3. Finally got rid of the popping noise!
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 10-19-2004, 02:24 PM
  4. noise investigation
    By lookinco in forum Power Supplies
    Last Post: 09-23-2004, 03:41 AM
  5. Noise!! AARGH!
    By sq_geek in forum General Hardware Discussion
    Last Post: 09-21-2004, 02:33 PM
