Results 1 to 10 of 11
Thread: Low output.
    Aug 2005
    Low output.
    I've been learking for about half a year but haven't posted yet....anyway I got my comp set up in my car and everything is great (runs perfect no amp poop no ground loops...thank good) but I do have one problem the output to my speakers is really low and I'm not sure exactly what it is I have some ideas but not positive.
    1. I got a cheap amp to try and save money cus I'm on a tight budget....but I don't think that is the problem.
    2. I'm still using stock speakers again to try and save money but I've never had a problem with them with my stock HU...so I don't think that would be the problem.
    3. The line out/speaker jack on my computer isn't giving enough power.(that what I think it is.)
    if it's #3 what could I do to fix that....I don't need it to be REALY load cus I don't listen to music that load but right now I can't hear the music very well on the highway going 70+ due to ground noise (and my exhaust isn't that quiet either)
    Constant Bitrate ashbosh's Avatar
    Mar 2004
    Stock speakers are usually highly efficient since the stock head unit usually does not have amplifier in it. Your aftermarket comps may not be as efficient as the stock ones. You can try stock speakers with your current setup to see how it sounds. If not go with #1.
    Current project ■■■■■■■■■■■■■■■■■■■■■■■■■■___ 85%
    Xenarc 700TS, Mobile Athlon 1GHz, Soyo K7VME, 30Gb HD, Slimline DVD drive, TB Santa Cruz, Opus 120W
    Holux G210
    03 Acura TL, Zapco & Precision Power amps, Adire Koda comps & EDesign 12" sub.
    Sep 2003
    Austin, TX
    I think he is using stock speakers.
    Aug 2005
    Yep I am
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    are you sure the plugs in all the way? What kinda rca to 1/8" converter are you using. Some of the ones i've seen (from radioshack) suck ***.
    Maximum Bitrate SAScooby's Avatar
    Feb 2004
    Johannesburg, South Africa
    check that your output levels in your control panel on your pc are correct
    I think your wave volume will be low
    and your software is probably controlling master volume or the other way around, check it out, my first install 18months ago had this, I soon learnt to check this first
    Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
    Aug 2005
    Quote Originally Posted by Sonicxtacy02
    yep it's in all the way that was my first guess.....and I am useing one from radio shack (that was cheap) but I don't think that's my problem cus I tried it on my desktop going to my home theartor and it sounds fine.
    Quote Originally Posted by SAScooby
    and your software is probably controlling master volume or the other way around, check it out, my first install 18months ago had this, I soon learnt to check this first.
    If your talking about the volume controls (volume wave, synth, cd player, line in) everything is maxed to 100%
    thanks for all the help any other thoughts?? I've done a little reading and a standard sound card puts out 2.2V while a standard HU puts out about 5V and it looks like I need a line driver but I'm not sure if anyone has any experiance with one let me know.
    thanks again
    Jul 2005
    well i noticed with roadrunner frontend, that at first it wasn't controlling the volume that i wanted, i played with it, set it to do the master volume, i set wave volume to 100%, and master at 85 or 90% then i pushed up the mixer volume... which is winamps volume until it was basically as loud as i'd ever want it, then it worked great, sound isn't as good when u have winamp volume maxed and then turn master up and down i didn't find, but that fixed my quiet sound issue, but i also run straight to amps
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    What about the gain on your amp too? I know you found a solution but that could be something to check aswell
    Aug 2005
    Quote Originally Posted by FyreDaug
    my gain is at about 1/3 of the way up...if I go any higher I start to get a lot of distortion.
  1. The "Official" low profile card post
    By lakorai in forum General Hardware Discussion
    Last Post: 05-22-2005, 09:49 PM
  2. Aux-in Analog audio... will it output from the SPDIF on mainboard?
    By coachreed in forum General Hardware Discussion
    Last Post: 05-07-2005, 10:57 PM
  3. Is all coax/optical spdif output created equal?
    By Choser in forum General Hardware Discussion
    Last Post: 12-19-2004, 03:48 PM
  4. XMDirect Digital Audio Output ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 10-11-2004, 09:10 PM
  5. Basic Stamps???
    By adjones in forum Power Supplies
    Last Post: 08-24-2004, 12:28 AM
