Results 1 to 8 of 8
Thread: Grounding Question what size wire
    Variable Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Hi all
    I am trying to fix this engine wine problem I have.
    I am going to ground inverter(400 watt),computer (Shuttle Pc),7"monitor,head unit,sirius radio to 1 grounding block.
    My question is what size grounding wire should I use for all that? I was thinking 4ga. or should i use 1/0?
    What do you think?
    Michael
    Aug 2005
    your ground size wire has to be the same as the power wire so if your power wire is 4ga then your ground has to be 4ga to
    Feb 2005
    Huntsville, AL
    Quote Originally Posted by heuninck
    Thanks for the response.
    I understand that.. but I do not have just 1 wire I have multiple wires going to the grounding block
    Then the grounding block will be attached to the chasis with 1 single wire but I am trying to find out what size wire to attach to the chasis to use for all this.
    example:
    The inverter is 8ga,ground for the computer case,mb, power supply etc?...head unit think is 14ga,sirius radio think is 16 or 18ga,monitor think is 16 or 18 ga also
    so with the 18ga inverter wire, 1 14ga head unit wire,what ever i need to ground the computer case, and the other multiple 16-18ga wires would 4ga be ok or should I go with 1/0 wire
    Thanks Again
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    The biggest you can get. If the largest you have in terms of power wire is 8 ga, and the rest are smaller, 4ga should be able to handle it.
    Newbie goosef350's Avatar
    Jul 2005
    San Jose, Ca
    ground everything with the same size power wire that is comming off your battery
    _
    Mar 2004
    Little Elm, Texas
    just use 1/0 and be safe....a short section of 1/0 won't put you back that much, just make sure that your grounding block can take 1/0...
    Jan Bennett
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    4ga will be fine
    May 2005
    never hurts to over size your wire and your local welding shop should sell 1/0 by the ft and if your dist block will not handle 1/0 we have used 2 4ga in to the dist. block just remember to clean your grounding to the car really good and dont over fuse your equipment
  1. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 01:29 AM
  2. relay grounding question
    By mushrew0 in forum Power Supplies
    Last Post: 07-03-2005, 11:02 PM
  3. Iguidance Font size question
    By Sonicxtacy02 in forum GPS
    Last Post: 04-03-2005, 08:24 AM
  4. Grounding question.
    By barney0001 in forum General Hardware Discussion
    Last Post: 09-23-2004, 10:43 AM
  5. Replies: 13
    Last Post: 09-20-2004, 06:01 PM
