if your amps out put power is not really large say 40-60watts rms per ch should be able to travel just fine across your factory wire harness but the power to the amp is in accordance with the size of you amp ..never hurts to over size the power wires pos..and ground just dont over size your fuses and dont forget amps make lots of heat so think of cooling in your install location
LinkBack URL
About LinkBacks
