Results 1 to 7 of 7
Thread: Amp Probelm (Constant Bass)
    Aug 2005
    Hey
    I dont know how to explain this but I am haveing a weird probelm and I think its the amp. The amp is bridged and is only being used by a 15 inch sub. Anyways, for somereason when i plug in the cables to the input and as soon as I start turning up the gain from 0. It just gets this constant rumbling bass..... even if theres no song on. Its just a constant bass. What am I doing wrong here?
    Oct 2004
    NY
    could be a damaged rca... unplug it & see if the noise goes away....
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I have the same problem with my subs, but I haven't done anything to correct it yet. I think my problem is that I'm getting interferance from the power wire, I think I need to reroute my rca.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    If you subs hits soon as you plug your rca in, then i got you fix.. Rca in the headunit is not grounded.. It came unsoldier. You make sure this is your problem hook up rca up to the amp and ground one side of the rca. It will go away.
    Aug 2005
    I will try that later on tonight, its too damn hot outside right now... hehe. THanks for the help. I am a newb when it comes to amps... also what does all the crossover switches mean, the the lp hp and then theres another option i forget what its called at this time, do those settings matter?
    Thanks again for the help.
    Oct 2004
    NY
    lp is low pass hp is high pass... the third control may be frequency of cross over.....
    Aug 2005
    What setting should i keep the subs under, hp or lp? Also, if the rca in the headunit isnt makeing contact with the negative anymore, should i take it apart and fix it or send it to pioneer?
  1. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  2. car battery
    By Slurpee in forum General Hardware Discussion
    Last Post: 09-08-2007, 06:30 PM
  3. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  4. vw mk4 monson amp and another amp
    By colorless in forum Car Audio
    Last Post: 10-03-2005, 01:32 PM
  5. I need to some basic information about amps
    By Bust_A_Cap in forum Car Audio
    Last Post: 08-01-2004, 10:31 PM
