i use something very similar, however my interconnect wire from my HU to the trunk is male to male, so my RCA plugs are femail
Hi guy just a bit of help here is this cable the right one for connecting the pc to the head unit in my car? or do i need to get a sound card with the RCA outputs and a cable with the 2 connectors at either end.
PC Components:
My work log
sorry i don't understand what the interconnect wire is can you find a pciture of the cables your on about
Cheers
Well your best bet is if your HU has an AUX in or aux in adapter, in which case you follow the format of that but I'm guessing that they are normally two RCA (left/right).
James Radcliffe
James@GoDivine.net
Planning (Phase I)
|||||++++++| 40% Making Final Pre-Purchase Plans
Car Stereo (Phase II)
|||||||||++| 80% - Building box, getting ready to wire
Carputer (Phase III)
||+++++++++| 10% Desiging CarPC case
bloody 306 owners! HOW TO: Get sound from PC to Car Stereo / Amp
With 306 it is difficult to make a PCCAR because of the screen!!!
When the screen flip up, it hit the aerators...
You should have had the same problem ?
First figure out if your HU takes RCA inputs. Some do not.
