Your car antenna does not use the same signals as do TV's. You need another antenna.
where could i get an antenna adapter in order to connect my antenna to my WinTV
i cant see there other end very well, but is this what i need?
http://www.cardomain.com/item/SCOFDARB
----][-][--][-][-I-][-][][][-][-I-][---][---][I--][
----][-][--][-][---][-][][][-][---][--][][--][-I-][
][][][-][][][-][---][-][-----][---][-][--][-][--I][
----------------------][-Carputer-|====|75%
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
I know, but i was talking about connecting it to the FM on the wintv device
ok so just buy one of these:
http://www.goodguys.com/adtemplate.a...7&catky=207135
Cut the male end of the off and plug the female end into the existing male end of your fm antenna.
Next, buy this:
http://www.radioshack.com/product.as...t%5Fid=278-255
And crimp that on to the part where you cut the male end off.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Originally Posted by JuMpMaN6235
I think these will solve your problem:
lol ur about 4 months too late, j/k... but thanks, i actually never did get around to installing the tv/fm unit... ill prolly do it in the spring... But where did you get those?
EDIT: nm i see radioshack, Thanks
