Results 1 to 5 of 5
Thread: help with 1/0 wire compression unions
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    hi all thanks for looking...
    I am looking for a 1/0 wire compression unions does anyone know where to get these online?.It looks like it is about 6" long you tighen up the nuts to hold the wires together then it looks like there is some thick heat shrink tubing on it also.
    thanks
    looks like this...
    _
    Mar 2004
    Little Elm, Texas
    I have never seen aything like that before....might try an electrical supply house locally?
    one of those places where you would have to talk to an electrician to find the supply house...
    otherwise, why not solder it? or even better! a distribution block, one with fuses even!
    Jan Bennett
    that thing doesnt even look like it belongs in a car. hmm.
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    You are best off purchaseing automotive distribution blocks. They come in a variety of configurations. They are by far the most reliable way of extending and tapping off connections. They are available at any good Car Audio shop or on line.
    Low Bitrate widower's Avatar
    Jun 2005
    The picture looks much like the connectors for submersible water pumps. Last time I bought mine at Home Depot. The heatshrink has a glue inside it that makes the connection water tight.
  1. FAQ: How to Wire an OPUS PSU
    By Quattro in forum The FAQ Emporium
    Last Post: 08-26-2006, 01:38 PM
  2. Morex 60W car kit - 4 or 6 wire?
    By MVShibui in forum Power Supplies
    Last Post: 05-09-2005, 02:28 PM
  3. FS: 12' Rockford 1/0 Gauge Power/Ground Wire - New
    By CrazyModGSR in forum Classified Archive
    Last Post: 09-28-2004, 01:52 PM
  4. Replies: 37
    Last Post: 05-17-2004, 08:01 PM
  5. ignition wire for opus psu
    By liquid_smoke in forum Power Supplies
    Last Post: 09-09-2003, 11:58 PM
