Results 1 to 5 of 5
Thread: STi Speaker Wiring Setup?
    Mar 2005
    North Carolina
    To startoff this will be my first time installing an amplifier and everything about my stereo is stock.
    I have a question about running the speaker wires. Since they already are routed to a harness behind the head unit I was wondering if I would be able to just connect a harness (which has longer speaker wires attached) to the factory harness, then run the speaker wires from the newly plugged in harness to the amplifier that will sit either in the trunk or under the front seat. I do not want to remove the factory harness. Should I be concerned about the additional length of wire that will be added between the speaker/amp connection? Should I run a thicker gauge wire from the "New" harness or should it be the same gauge as the stock wire gauge running to the existing harness? Also, if this is a workable solution - whats a good place to buy the required harness?
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    Don't worry about it. Its alright to use the adapter. In fact, in most situations, the preferred method. As for the place to get it, go to the local audio shop. They WILL have them.
    But as for the car, you should really get rid of that one quick. I'll take it off of your hands. I won't even charge you for it.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    Yep - Subaru has used the same radio harness pinout for a number of years. I'd recommend 16 gauge speaker wire.
    If you're keeping the stock stereo you'll want to buy two harnesses; one that plugs into the stock radio and one that plugs into the wiring harness. Then you wire them together, substituting the wires from your amp and capping off the speaker outputs of the stock radio. It'll make sense when you're looking at it. The bad part is most places don't stock the harness for the OEM radio so you'll have to order it.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Are you keeping the stock speakers too?
    Where's the computer in your diagram?
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
    Mar 2005
    North Carolina
    Thanks for the info. I will be keeping the stock speakers for now. Im putting in an amp just so that Ill have the ability to output the music from an in-dash car pc. I will actually be ditching the head unit and replacing it with the car pc shortly after the amp is wired in. I just want to take things slow and a step at a time to make sure I do them right.
  1. Replies: 7
    Last Post: 06-27-2005, 10:45 PM
  2. Setup Help
    By trance728 in forum Newbie
    Last Post: 05-07-2005, 04:28 PM
  3. Speaker setup help
    By Ascension in forum Car Audio
    Last Post: 04-25-2005, 08:15 PM
  4. FS: Complete DennisK setup: 8.4" vga touch!
    By InFix in forum Classified Archive
    Last Post: 10-03-2003, 05:25 AM
  5. Specific wiring schematic 4 Optrex DMC40457?
    By sooty in forum LCD/Display
    Last Post: 07-17-2001, 03:11 AM
