Results 1 to 8 of 8
Thread: what do people think of this amp? (blaupunkt)
    Newbie davebateman's Avatar
    Apr 2005
    Manchester, UK
    now ive always considered blaupunkt to be quite good, am i right?
    Velocity VD504 (cant find info on blau site.)
    Technical features
    # Max. total power (4 ohms) 4x100W (4-channel op.)
    # Max. total power (4 ohms) 2x300W (2-channel op.)
    # RMS power (THD@ 0,07 %) (4 ohms) 4x50W / 2x150W
    # RMS power (THD@ 0,07 %) (2 ohms) 4x80W
    # Channels 4/3/2
    # Frequency response 20-20.000 Hz
    # S/N ratio dB/A > 95 dB
    # Total harmonic distortion 0,07 % (@full rated power)
    # Input impedance > 20 kohms
    # Gain adjust 0.3 - 8 V
    # Load stability 2 ohms (4-channel op.)
    # Variable low pass filter 40-160 Hz
    # Variable high pass filter 40-600 Hz
    # Subsonic filter 20-55 Hz variable
    # Bass boost + 15 dB (45 Hz)
    # Inputs 4 x Cinch/RCA, gold-plated
    # Outputs 4 x speaker, gold-plated,
    # Preamp-Out 2 x preamp out, gold-plated
    # Power-on LED/protection LED blue/red
    # Heat sink chromium-plated & engraved
    # Dimensions WxHxD (mm) 465 x 58 x 278
    is that any good? its £150 for it and im considering getting 2.
    basically need an amp to power front L, front R, rear L, Rear R, Centrex2 and sub(2 channels bridged).
    Maximum Bitrate Mad Ad's Avatar
    Oct 2004
    Hertfordshire UK
    RMS power (4 ohms) 4x50W ... for 150 quid? Sounds a bit steep but i dont know the amp either, have another look about. The s/n is reasonable but the low frequency response of 20Hz is a bit on the high side, id expect 10hz for that money
    Btw, they are listed in the french section of the blaupunkt site- perhaps CAD imported them?
    Jul 2005
    20hz is on the high side???
    the human ear is not capeable of hearing anything below 20hz or above 20khz.
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by sharpy39
    Can't hear it, but you can feel it.
    How much is that amp is US currency?
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    If you're considering a sub that 10hz will make a difference.
    Jul 2005
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    That's a four channel amp. And not one designed (Very well) to take a sub. If you want one that can do all that, you'd need like, an MTX. Or buy a 5 or 6 channel amplifier.
    20k is not high. That's normal.
    If you want to use it for a sub, however, as said, 20 Hz is on the high side for a sub, considering the lowpass filter goes down to 40Hz..
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    Going with a 4 channel is not going to make you happy.
    You need at least a 5 or 6 channel amp or go with seperate amps.
    Seperates give you the most flexibility. But there is enough to be said about haveing everything wired to a single amp.
    Too bad you are in the UK we are having a sale on all our Soundstream stuff on http://www.accentsounds.com enter the site and click on the EBAY button on the left.
  1. Replies: 30
    Last Post: 07-28-2010, 11:14 PM
  2. Could my amp be bad or did i miss something?
    By sansoo24 in forum Car Audio
    Last Post: 03-05-2007, 02:45 AM
  3. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 08:03 PM
  4. People with NO HeadUnit, Recommand AMP!!
    By camsgs3 in forum Newbie
    Last Post: 07-26-2004, 07:38 PM
  5. amp +smoke = bad USUALLY
    By pcman_cortina in forum Off Topic
    Last Post: 07-09-2002, 04:20 AM
