Results 1 to 5 of 5
Thread: help sound card not powerful enough!!!
    Nov 2004
    providence RI
    so i have an onboard card and when i hook it up to my amp i dont get a good sound outta of it. turn it up alllll the way and its still very low volume. so i go out and buy a pre amp line driver. and i get way better sound goes really loud but when its down low i get this horible feedback noise. i get poppin noise and the wine noise. and its def not the ground. any help would be appreciated. ps i already and found nothing i have also switched out the card for a newer one and no luck.
    need help putting up my carputer!!!! help me out guys and please be kind to the newbiee
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by 99acuracl
    its def not the ground. .
    Thats what they all say......
    I had a set of speakers, creative 5.1, worked fine indoors but when I put the in the van (www.devonkingtravel.co.uk) with the laptop and a lcd they whistled.
    Seems ground on the 3.5mm jack was not DC ground and created a 'ground loop'.
    Cutting the ground screen on the jack and the fitting a capacitor (2.2uf 25v) re connected the ground at audio levels but allowed dc blocking.
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    just a thought ifits dc offset problems on the audio lines you may need to put some caps on the actual audio feed as well as the grounds.
    Jul 2005
    Malaysia
    two possibilities... (1) if you're using an inverter, your power plug is not grounded properly. (2) you need a ground-loop isolator.
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    You could always test the wiring by plugging the jack into a portable mp3 player, walkman or similar. That will test for both ground loop problems and defective ground, ie:
    no horrible feedback now - you have a ground loop problem
    normal volume - you have a PC sound problem
    no change - you have a cable problem, possibly a bad ground.
  1. Sound card issues
    By gboy in forum Newbie
    Last Post: 02-25-2005, 10:38 AM
  2. sound card on home computer....
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 02-24-2005, 10:00 PM
  3. Sound card / noise
    By Tha Hombre in forum General Hardware Discussion
    Last Post: 05-16-2004, 12:01 AM
  4. How to hook it all up/How many watts?/What sound card to buy?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-22-2004, 11:28 PM
  5. Any opinions on the Phillips Aurillium external sound card?
    By UMM in forum General Hardware Discussion
    Last Post: 02-27-2004, 04:39 PM
