Results 1 to 8 of 8
Thread: Time Correction (DSP) Winamp?
    Jul 2004
    Anyone know where i can get "Time Correction" plugin for Winamp or someting else player?
    Constant Bitrate 00christian00's Avatar
    Apr 2005
    Italy,Ancona
    Intervideo windvd has multichannel time correction,but don't know why it's enabled only with disc(dvd audio,dvd video haven't tried cd audio).If you want to play a file on the hd (unless is a disc image) you can't use it.You can specify correction with 1 ms scale.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    do you have a soundblaster pci card? you can get time correction through the kxproject driver and a plugin
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jul 2004
    I use motherboard integrated AC97 audio (6-channel)
    Jun 2004
    Bay Area, California
    a 1 ms scale in the car is completely useless. you could set it at the lowest setting, and youd be basically as good off as you were without T/A! arguably, you can say you were better off before!
    are there any solutions that have at least a .1 ms resolution? higher resolution would be better still, too...
    Apr 2005
    Italy,Ancona
    Are you sure?I don't think even the alpine dsp have a resolution of more than 1ms
    Jun 2004
    im sure it must, even the eclipse 8443 has a resolution of .1 ms. Alto's Drive 30 has a resolution of .02 ms (a little extreeme)
    edit: 1 ms of correction is to correct just over a foot of offset placement! works great in a house. probably not the car so well
    Jun 2004
    F#1 status has .1 ms resolution, just checked.
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. Here's an easy one (DSP question)
    By ummagawd in forum Road Runner
    Last Post: 12-06-2005, 08:24 AM
  3. Winamp Plug-In Sets iPod Music Free
    By Gobby in forum General MP3Car Discussion
    Last Post: 08-12-2005, 01:31 PM
  4. Replies: 6
    Last Post: 06-10-2005, 04:45 AM
  5. Can FrodoPlayer use WinAmp or WMP DSP plugins?
    By ruairi in forum FrodoPlayer
    Last Post: 02-07-2005, 03:38 PM
