What's "every couple" of minutes? Is the amount of time it stays off AND on consistent? Try testing each amp individually and if both are having the same problem, then I would triplecheck the power and audio lines.
Does one amp feed the audio signal to the other? If the producer turns off, then the consumer won't have an audio signal to reproduce... You need to give us a little more info.
LinkBack URL
About LinkBacks
