Results 1 to 10 of 10
Thread: How to run HU less with Bose
    Oct 2004
    Orlando(UCF)
    How do i run HU-less with Bose?
    I was wondering how i would connect my carputer up to my bose system without going through the headunit.
    I read one post on here about just going from my carputer to a preamp and then from there to my amps powering the speakers. Is this correct?
    Oct 2004
    Orlando(UCF)
    oh btw, i got a 2002 Audi A4
    Oct 2004
    NY
    if you want to keep the bose amps & everything else intact then source a bose headunit adaptor..... pac, scoche & I thinka few others make them to replace a bose head with an aftermarket.... you would just interface the pc to that...
    Oct 2004
    Orlando(UCF)
    Ok but the idea is to just eliminate a headunit alltogether so it doesnt just take up room.
    Oct 2004
    Orlando(UCF)
    basically my question is could i just run my carputer to an equalizer such as this one:
    http://www.autotoys.com/x/catalog/PY...EX_p_2699.html
    and then from there run the outputs to my speakers and sub.
    Oct 2004
    NY
    what I'm talking about does eliminate the head unit.... you will still need to interface to the rest of the system.... that is what the adaptor is for.... as far as a pyramid eq
    Oct 2004
    Orlando(UCF)
    Quote Originally Posted by turbocad6
    oh ok! i re-read your first post and it make sense now...
    thanks man
    Oct 2004
    Orlando(UCF)
    i assume this is what you mean: http://www.crutchfield.com/S-U89MqGK....asp?i=127OEM2
    but crutchfield says it wont work for my model.
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    you need a bose interface, like a soundgate adapter. check out the corvette install in the show off your project area. one of them has the computer interfaced with bose
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    HUless means Boseless. If you want it to sound half way decent anyways.
  1. Replies: 13
    Last Post: 10-03-2005, 03:41 AM
  2. Full featured carpc plus seperate DVD HU...any ideas how to hook this up?
    By bigshooter in forum General Hardware Discussion
    Last Post: 12-25-2004, 12:36 AM
  3. Getting rid of HU
    By techy101 in forum Car Audio
    Last Post: 09-21-2004, 06:54 AM
  4. Replies: 13
    Last Post: 08-22-2004, 04:52 PM
  5. OEM HU Input for 98 Honda Civic.
    By chewtoy in forum General Hardware Discussion
    Last Post: 11-01-2001, 04:46 PM
