Results 1 to 4 of 4
Thread: sirius engine wine solution?
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    Hi all 1st wanted to thank everyone who was helping me with my engine wine I had posted before about a month ago got that fixed.
    New problem:
    I am trying to use my Sirius sportster in the car until I can afford the kit to integrate it into the computer and use it with the front-end.
    no mater how I hook it up get tones of electrical interference and engine wine. going into the line-in on the soundcard.
    1: plugged into the cigarette lighter no good
    2 : used the power wire from the cigarette lighter grounded it to chassis as close a possible(12"), straight to battery, in back where I have everything else grounded to i.e. amps,computer inverter no good
    3: used the switched power for the radio grounded it to all the points in #2
    no good
    the only way it works perfect is if I plug in the 120v dc adapter in the inverter and use it that way.
    any other ideas on what I can do?
    Michael
    Constant Bitrate CornToeGoblin's Avatar
    Dec 2004
    Texas
    i'l tell you if you buy me alcohol... any kind as long as it gets me drunk
    2008 Civic... Sound system... then carputer install...
    WORK IN PROGRESS
    If you look at my avatar closely, you can see a chick with two big knockers....
    Feb 2005
    Huntsville, AL
    homebrew on its way!!!!
    Variable Bitrate fromplanetbob's Avatar
    Jan 2005
    Get a ground loop isolator (at radio shack or any car audio shop) and insert it between the line out of the sportster and the line in of your sound card.
  1. engine wine know how its there but can't get rid of
    By michaelrj9 in forum Car Audio
    Last Post: 11-05-2005, 09:58 AM
  2. Replies: 3
    Last Post: 07-31-2005, 09:59 PM
  3. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 05:55 PM
  4. Anyone using Timetrax + Sirius solution
    By DaveDog in forum General Hardware Discussion
    Last Post: 02-02-2005, 07:00 PM
  5. Sirius Carputer solution in the works??
    By biglips31 in forum General Hardware Discussion
    Last Post: 11-18-2004, 01:20 PM
