Results 1 to 3 of 3
Thread: Audigy NX to stock amp
    Jul 2005
    I've done a search and tried to read through as much as I reasonably could, but couldn't find a definitive answer to my question.
    Basically, I'm running my setup HU-less, with sound coming out of the Audigy NX into my stock amp. Problem is, the amp's only got two proprietary plugs (no RCA inputs). What's the best way to get the sound working? This is what I've been thinking so far:
    1/8" jack out of audigy nx -> 2 RCA jacks, then cut and splice (solder?) each of those RCA wires to their respective speaker wires running into the amp, along with the grounds.
    Is that feasible? Or would I need some kind of line-level converter or pre-amp thingy? Thanks in advance for any help.
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    If your sound card output works with normal earphones it will be fine to feed the amp.
    If you're concerned, set the PC's volume to min and gradually turn it up with something playing. If you hear clipping stop, that's as far as you can go, but I doubt there will be any problems.
    Mar 2004
    Los Angles
    I am a car stereo installer my name is Stefan email me at port20@socal.rr.com with your cars year make model and witch audio system you have bose harmon etc. make the subject line read mp3car and I will tell you how to do it it is very easy
  1. Replies: 7
    Last Post: 02-21-2008, 12:49 PM
  2. PC Motherboard to 1 amp or 2?
    By hanzacra in forum General Hardware Discussion
    Last Post: 11-27-2007, 03:41 AM
  3. Audigy 2 NX software/cd?
    By Urinemachine in forum Car Audio
    Last Post: 06-14-2005, 07:49 AM
  4. Audigy 2 NX and subwoofer, whats the deal?
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-15-2005, 02:17 AM
  5. Audigy NX 2 review
    By eleventh in forum General Hardware Discussion
    Last Post: 03-26-2005, 02:06 AM
